NSClient Reporting Twice the Memory in a Windows Machine
w14219
Post by w14219 »
Nagios Server: Nagios Core 3.31
Server OS: Ubuntu 10.04.3
Issue: I am finding that all the Windows Servers and Windows Workstations are reporting twice the amount of physical memory available in the machine.
Question:
Why is Nagios reporting twice the actual amount of Physical memory installed in the computer? How can I resolve this?
Thank you,
Mike
Re: NSClient Reporting Twice the Memory in a Windows Machine
This depends on what command you are sending but several use all memory (including paged)
If you were using http://nsclient.org/nscp/wiki/CheckMem
you would need to add type=physical to the command
dbeasley
Post by dbeasley »
Just wanted to second this that I had the same issue and yes it's because the Windows "NSClient" basic memory check includes physical plus paged. Was an awesome surprise when we had a SQL server technically out of memory but I thought it was running just fine at 50%.
You'll need to switch to the NRPE memory checks and specify physical as Scott Wilkerson said. This may require tweaking your NSC.ini file.
