NagiosXI import error
aditya.c.anand
Post by aditya.c.anand »
Hello Team,
We were trying to configure hardware monitoring via :
https://exchange.nagios.org/directory/P ... r)/details
Here after last step, we can see that the alerts were configured in Nagios core and XI but when we checked for the configuration in CCM no such files were present.
We then tried to import the "/usr/local/nagios/etc/ilo/ilo.cfg" file in NagiosXI. Import was successful but when applied the configuration it is throwing error.
Please refer the attached doc file for screenshots and error.
Kindly help.
Regards,
Aditya Anand
Re: NagiosXI import error
When importing a config file in to XI, the commands, templates, contacts, etc.. that are defined in the config file that you are importing, has to exist first.
If not, is will create a configuration error like you are having.
What you need to do is to open the ilo.cfg config file and not the templates, commands, contacts, groups, etc and see if they exist in XI.
If not, add them and then try to import the config file.
Check this file as well if it exists.
/usr/local/nagios/etc/hosts/NagiosXI Test.cfg
