Cannot find module SNMPv2-SMI Error
pendrgn
Post by pendrgn »
Hi all, I'm a fairly new to Linux and Nagios.
I installed Nagios3 on Ubuntu 11.04, the install went well with no major issues. However, when i try to monitor a Cisco switch -port link status- i get the following error. Uptime check doesn't work as well.
External command error: MIB search path: /root/.snmp/mibs:/usr/share/mibs/site:/usr/share/snmp/mibs:/usr/share/mibs/iana:/usr/share/mibs/ietf:/usr/share/mibs/netsnmp
Cannot find module (SNMPv2-SMI): At line 0 in (none)
ifOperStatus.1: Unknown Object Identifier (Sub-id not found: (top) -> ifOperStatus)
snmpwalk v1 and v2c to the switch works fine.
Does anyone have a solution to this issue?
Regards, Pendrgn
mascir
Re: Cannot find module SNMPv2-SMI Error
Post by mascir »
Hi All,
i have the same issue...
***External command error: MIB search path: /home/mascir/.snmp/mibs:/usr/share/mibs/site:/usr/share/snmp/mibs:/usr/share/mibs/iana:/usr/share/mibs/ietf:/usr/share/mibs/netsnmp***
snmp works fine.
how i can set the right path or var?
thanx in advance :)
mascir
Post by mascir »
Hi All...
snmp on my ubuntu 12.04 works fine...
how i ca fix it?
thanx in advance
