Zookeeper script throwing an error
shamrozkadiwal
Hey All,
I have setup some services to monitor zookeeper and have been getting an error as "(Return code of 127 is out of bounds - plugin may be missing) " This error doesn't make sense because script is there for sure. In addition, nrpe client on that server is running because other top 4 services are green. Please let me to fix this issue.
FYI, I am following this link to setup zookeeper services
http://svn.apache.org/repos/asf/zookeep ... onitoring/
check_zookeeper_apache.py- Zookeeper Script
- (11.09 KiB) Downloaded 437 times
Re: Zookeeper script throwing an error
Did you create a command definition in the nrpe.cfg file for the Zookeeper script?
Can you post the command that you defined in the nrpe.cfg file as well as the service check that is defined on the Nagios server so we can view the settings?
Thanks.
Thanks.
shamrozkadiwal
@tgriep, you mean command.cfg file where all the commands are defined.
/etc/nagios/commands/command.cfg
/etc/nagios/services/services.solr.cfg
define command
command_name check_zookeeper
command_line /usr/lib/nagios/plugins/check_zookeeper_apache.py -s $HOSTADDRESS$:4150 -o nagios -k '$ARG1$' -w '$ARG2$' -c '$ARG3$'
}Code: Select all
hostgroup_name zookeeper-servers
use gen-solr-svc
servicegroups zookeeper-services
service_description ZK_Open_File_Descriptors_Count
check_command check_zookeeper!zk_open_file_descriptor_count!500!800
use gen-solr-svc
service_description ZK_Ephemerals_Count
check_command check_zookeeper!zk_ephemerals_count!10000!100000
use gen-solr-svc
service_description ZK_Avg_Latency
check_command check_zookeeper!zk_avg_latency!500!1000
use gen-solr-svc
service_description ZK_Max_Latency
check_command check_zookeeper!zk_max_latency!1000!2000
use gen-solr-svc
service_description ZK_Min_Latency
check_command check_zookeeper!zk_min_latency!500!1000
use gen-solr-svc
service_description ZK_Outstanding_Requests
check_command check_zookeeper!zk_outstanding_requests!20!50
use gen-solr-svc
service_description ZK_Watch_Count
check_command check_zookeeper!zk_watch_count!100!500
}Re: Zookeeper script throwing an error
Can you run the plugin on the Nagios server while you are logged in to it as the nagios user?
Run this to change to the nagios user
Then run the plugin, replace xxx.xxx.xxx.xxx with the IP address of the Zookeeper server.
Post the full output.
In your first post, you mentioned NRPE, is the plugin suppose to run on the remote server using NRPE?
I just want to clarify it.
su - nagiosCode: Select all
/usr/lib/nagios/plugins/check_zookeeper.py -s xxx.xxx.xxx.xxx:80 -o nagios -k zk_open_file_descriptor_count -w 500 -c 800In your first post, you mentioned NRPE, is the plugin suppose to run on the remote server using NRPE?
shamrozkadiwal
@tgriep, I turned into nagios user and ran below commands
nagios@camel / $ /usr/lib/nagios/plugins/check_zookeeper_apache.py -s 10.180.130.76:80 -o nagios -k zk_open_file_descriptor_count -w 500 -c 800
: No such file or directory
nagios@camel / $
nagios@camel / $ ls -al /usr/lib/nagios/plugins/check_zookeeper_apache.py
-rwxr-xr-x 1 nagios nagios 11352 Apr 17 07:58 /usr/lib/nagios/plugins/check_zookeeper_apache.py
nagios@camel / $
In the top of the script, it calls the env application to create is own environment.
This is the line from the script.
Is the env application in the /usr/bin folder?
If it is in a different folder, update the script to the correct path and see if the plugin runs.
If it still fails, run the script with python in verbose mode and post the output to see that the error is.
#! /usr/bin/env pythonIf it is in a different folder, update the script to the correct path and see if the plugin runs.
python -v /usr/lib/nagios/plugins/check_zookeeper_apache.pyBe sure to check out our Knowledgebase for helpful articles and solutions!
shamrozkadiwal
camel bin # ls -al python
lrwxrwxrwx 1 root root 14 Dec 14 2016 python -> python-wrapper
camel bin # pwd
/usr/bin
camel bin #
camel bin # python -v /usr/lib/nagios/plugins/check_zookeeper_apache.py
# installing zipimport hook
import zipimport # builtin
# installed zipimport hook
# /usr/lib/python2.6/site.pyc matches /usr/lib/python2.6/site.py
import site # precompiled from /usr/lib/python2.6/site.pyc
# /usr/lib/python2.6/os.pyc matches /usr/lib/python2.6/os.py
import os # precompiled from /usr/lib/python2.6/os.pyc
import errno # builtin
import posix # builtin
# /usr/lib/python2.6/posixpath.pyc matches /usr/lib/python2.6/posixpath.py
import posixpath # precompiled from /usr/lib/python2.6/posixpath.pyc
# /usr/lib/python2.6/stat.pyc matches /usr/lib/python2.6/stat.py
import stat # precompiled from /usr/lib/python2.6/stat.pyc
# /usr/lib/python2.6/genericpath.pyc matches /usr/lib/python2.6/genericpath.py
import genericpath # precompiled from /usr/lib/python2.6/genericpath.pyc
# /usr/lib/python2.6/warnings.pyc matches /usr/lib/python2.6/warnings.py
import warnings # precompiled from /usr/lib/python2.6/warnings.pyc
# /usr/lib/python2.6/linecache.pyc matches /usr/lib/python2.6/linecache.py
import linecache # precompiled from /usr/lib/python2.6/linecache.pyc
# /usr/lib/python2.6/types.pyc matches /usr/lib/python2.6/types.py
import types # precompiled from /usr/lib/python2.6/types.pyc
# /usr/lib/python2.6/UserDict.pyc matches /usr/lib/python2.6/UserDict.py
import UserDict # precompiled from /usr/lib/python2.6/UserDict.pyc
# /usr/lib/python2.6/_abcoll.pyc matches /usr/lib/python2.6/_abcoll.py
import _abcoll # precompiled from /usr/lib/python2.6/_abcoll.pyc
# /usr/lib/python2.6/abc.pyc matches /usr/lib/python2.6/abc.py
import abc # precompiled from /usr/lib/python2.6/abc.pyc
# /usr/lib/python2.6/copy_reg.pyc matches /usr/lib/python2.6/copy_reg.py
import copy_reg # precompiled from /usr/lib/python2.6/copy_reg.pyc
import encodings # directory /usr/lib/python2.6/encodings
# /usr/lib/python2.6/encodings/__init__.pyc matches /usr/lib/python2.6/encodings/__init__.py
import encodings # precompiled from /usr/lib/python2.6/encodings/__init__.pyc
# /usr/lib/python2.6/codecs.pyc matches /usr/lib/python2.6/codecs.py
import codecs # precompiled from /usr/lib/python2.6/codecs.pyc
import _codecs # builtin
# /usr/lib/python2.6/encodings/aliases.pyc matches /usr/lib/python2.6/encodings/aliases.py
import encodings.aliases # precompiled from /usr/lib/python2.6/encodings/aliases.pyc
# /usr/lib/python2.6/encodings/ascii.pyc matches /usr/lib/python2.6/encodings/ascii.py
import encodings.ascii # precompiled from /usr/lib/python2.6/encodings/ascii.pyc
Python 2.6.4 (r264:75706, Nov 8 2010, 19:22:23)
[GCC 4.1.2 (Gentoo 4.1.2 p1.3)] on linux2
Type "help", "copyright", "credits" or "license" for more information.
# /usr/lib/python2.6/socket.pyc matches /usr/lib/python2.6/socket.py
import socket # precompiled from /usr/lib/python2.6/socket.pyc
dlopen("/usr/lib/python2.6/lib-dynload/_socket.so", 2);
import _socket # dynamically loaded from /usr/lib/python2.6/lib-dynload/_socket.so
dlopen("/usr/lib/python2.6/lib-dynload/_ssl.so", 2);
import _ssl # dynamically loaded from /usr/lib/python2.6/lib-dynload/_ssl.so
dlopen("/usr/lib/python2.6/lib-dynload/cStringIO.so", 2);
import cStringIO # dynamically loaded from /usr/lib/python2.6/lib-dynload/cStringIO.so
import logging # directory /usr/lib/python2.6/logging
# /usr/lib/python2.6/logging/__init__.pyc matches /usr/lib/python2.6/logging/__init__.py
import logging # precompiled from /usr/lib/python2.6/logging/__init__.pyc
dlopen("/usr/lib/python2.6/lib-dynload/time.so", 2);
import time # dynamically loaded from /usr/lib/python2.6/lib-dynload/time.so
# /usr/lib/python2.6/string.pyc matches /usr/lib/python2.6/string.py
import string # precompiled from /usr/lib/python2.6/string.pyc
# /usr/lib/python2.6/re.pyc matches /usr/lib/python2.6/re.py
import re # precompiled from /usr/lib/python2.6/re.pyc
# /usr/lib/python2.6/sre_compile.pyc matches /usr/lib/python2.6/sre_compile.py
import sre_compile # precompiled from /usr/lib/python2.6/sre_compile.pyc
import _sre # builtin
# /usr/lib/python2.6/sre_parse.pyc matches /usr/lib/python2.6/sre_parse.py
import sre_parse # precompiled from /usr/lib/python2.6/sre_parse.pyc
# /usr/lib/python2.6/sre_constants.pyc matches /usr/lib/python2.6/sre_constants.py
import sre_constants # precompiled from /usr/lib/python2.6/sre_constants.pyc
dlopen("/usr/lib/python2.6/lib-dynload/strop.so", 2);
import strop # dynamically loaded from /usr/lib/python2.6/lib-dynload/strop.so
# /usr/lib/python2.6/traceback.pyc matches /usr/lib/python2.6/traceback.py
import traceback # precompiled from /usr/lib/python2.6/traceback.pyc
import thread # builtin
# /usr/lib/python2.6/threading.pyc matches /usr/lib/python2.6/threading.py
import threading # precompiled from /usr/lib/python2.6/threading.pyc
# /usr/lib/python2.6/functools.pyc matches /usr/lib/python2.6/functools.py
import functools # precompiled from /usr/lib/python2.6/functools.pyc
dlopen("/usr/lib/python2.6/lib-dynload/_functools.so", 2);
import _functools # dynamically loaded from /usr/lib/python2.6/lib-dynload/_functools.so
# /usr/lib/python2.6/collections.pyc matches /usr/lib/python2.6/collections.py
import collections # precompiled from /usr/lib/python2.6/collections.pyc
dlopen("/usr/lib/python2.6/lib-dynload/_collections.so", 2);
import _collections # dynamically loaded from /usr/lib/python2.6/lib-dynload/_collections.so
dlopen("/usr/lib/python2.6/lib-dynload/operator.so", 2);
import operator # dynamically loaded from /usr/lib/python2.6/lib-dynload/operator.so
# /usr/lib/python2.6/keyword.pyc matches /usr/lib/python2.6/keyword.py
import keyword # precompiled from /usr/lib/python2.6/keyword.pyc
# /usr/lib/python2.6/atexit.pyc matches /usr/lib/python2.6/atexit.py
import atexit # precompiled from /usr/lib/python2.6/atexit.pyc
# /usr/lib/python2.6/subprocess.pyc matches /usr/lib/python2.6/subprocess.py
import subprocess # precompiled from /usr/lib/python2.6/subprocess.pyc
import gc # builtin
dlopen("/usr/lib/python2.6/lib-dynload/select.so", 2);
import select # dynamically loaded from /usr/lib/python2.6/lib-dynload/select.so
dlopen("/usr/lib/python2.6/lib-dynload/fcntl.so", 2);
import fcntl # dynamically loaded from /usr/lib/python2.6/lib-dynload/fcntl.so
# /usr/lib/python2.6/pickle.pyc matches /usr/lib/python2.6/pickle.py
import pickle # precompiled from /usr/lib/python2.6/pickle.pyc
import marshal # builtin
# /usr/lib/python2.6/struct.pyc matches /usr/lib/python2.6/struct.py
import struct # precompiled from /usr/lib/python2.6/struct.pyc
dlopen("/usr/lib/python2.6/lib-dynload/_struct.so", 2);
import _struct # dynamically loaded from /usr/lib/python2.6/lib-dynload/_struct.so
dlopen("/usr/lib/python2.6/lib-dynload/binascii.so", 2);
import binascii # dynamically loaded from /usr/lib/python2.6/lib-dynload/binascii.so
# /usr/lib/python2.6/StringIO.pyc matches /usr/lib/python2.6/StringIO.py
import StringIO # precompiled from /usr/lib/python2.6/StringIO.pyc
# /usr/lib/python2.6/optparse.pyc matches /usr/lib/python2.6/optparse.py
import optparse # precompiled from /usr/lib/python2.6/optparse.pyc
# /usr/lib/python2.6/textwrap.pyc matches /usr/lib/python2.6/textwrap.py
import textwrap # precompiled from /usr/lib/python2.6/textwrap.pyc
# /usr/lib/python2.6/gettext.pyc matches /usr/lib/python2.6/gettext.py
import gettext # precompiled from /usr/lib/python2.6/gettext.pyc
# /usr/lib/python2.6/locale.pyc matches /usr/lib/python2.6/locale.py
import locale # precompiled from /usr/lib/python2.6/locale.pyc
dlopen("/usr/lib/python2.6/lib-dynload/_locale.so", 2);
import _locale # dynamically loaded from /usr/lib/python2.6/lib-dynload/_locale.so
# /usr/lib/python2.6/copy.pyc matches /usr/lib/python2.6/copy.py
import copy # precompiled from /usr/lib/python2.6/copy.pyc
Usage: ./check_zookeeper.py <options>
check_zookeeper_apache.py: error: The list of servers is mandatory
# clear __builtin__._
# clear sys.path
# clear sys.argv
# clear sys.ps1
# clear sys.ps2
# clear sys.exitfunc
# clear sys.exc_type
# clear sys.exc_value
# clear sys.exc_traceback
# clear sys.last_type
# clear sys.last_value
# clear sys.last_traceback
# clear sys.path_hooks
# clear sys.path_importer_cache
# clear sys.meta_path
# clear sys.flags
# clear sys.float_info
# restore sys.stdin
# restore sys.stdout
# restore sys.stderr
# cleanup __main__
# cleanup[1] _collections
# cleanup[1] site
# cleanup[1] subprocess
# cleanup[1] select
# cleanup[1] gc
# cleanup[1] keyword
# cleanup[1] abc
# cleanup[1] gettext
# cleanup[1] sre_constants
# cleanup[1] collections
# cleanup[1] _codecs
# cleanup[1] _struct
# cleanup[1] _warnings
# cleanup[1] fcntl
# cleanup[1] zipimport
# cleanup[1] optparse
# cleanup[1] textwrap
# cleanup[1] copy
# cleanup[1] strop
# cleanup[1] _functools
# cleanup[1] _locale
# cleanup[1] logging
# cleanup[1] socket
# cleanup[1] thread
# cleanup[1] StringIO
# cleanup[1] pickle
# cleanup[1] signal
# cleanup[1] traceback
# cleanup[1] posix
# cleanup[1] exceptions
# cleanup[1] marshal
# cleanup[1] cStringIO
# cleanup[1] atexit
# cleanup[1] _ssl
# cleanup[1] locale
# cleanup[1] threading
# cleanup[1] _socket
# cleanup[1] binascii
# cleanup[1] string
# cleanup[1] struct
# cleanup[1] functools
# cleanup[1] encodings
# cleanup[1] operator
# cleanup[1] re
# cleanup[1] encodings.ascii
# cleanup[1] codecs
# cleanup[1] encodings.aliases
# cleanup[1] sre_compile
# cleanup[1] _sre
# cleanup[1] sre_parse
# cleanup[2] copy_reg
# cleanup[2] posixpath
# cleanup[2] errno
# cleanup[2] _abcoll
# cleanup[2] types
# cleanup[2] genericpath
# cleanup[2] stat
# cleanup[2] warnings
# cleanup[2] UserDict
# cleanup[2] os.path
# cleanup[2] linecache
# cleanup[2] time
# cleanup[2] os
# cleanup sys
# cleanup __builtin__
# cleanup ints: 26 unfreed ints
# cleanup floats: 2 unfreed floats
camel bin #Re: Zookeeper script throwing an error
So far, everything looks OK so I am going to ask some basic information about the Nagios system.
What version of Nagios Core are you running on the server?
What OS and release is the server running?
Login to the Nagios server as root, run all of the following commands and post the /tmp/info.txt file here so we can view it.
Thanks.
chage -l nagios >/tmp/info.txt
grep nag /etc/group >>/tmp/info.txt
ls -alR /usr/lib/nagios >>/tmp/info.txt
ls -alR /etc/nagios >>/tmp/info.txt
ls -al /usr/bin/env >>/tmp/info.txt
which env >>/tmp/info.txt
ps -ef --cols=300 >>/tmp/info.txt
grep -R -i zoo /etc/nagios/* >>/tmp/info.txtBe sure to check out our Knowledgebase for helpful articles and solutions!
shamrozkadiwal
I have attached info.txt file
info.txt- (37.51 KiB) Downloaded 414 times
Edit the following file
change this from
to
Save it
The plugins folder is soft linked to another location so I will need you to run this and post the /tmp/info.txt file here so we can view it.
In the info.txt file, I see this command. Could this one be causing the error?
Can you post this file from the server?
Thanks.
/etc/groupCode: Select all
nagios:x:440:apache,rastewCode: Select all
nagios:x:440:nagios,apache,rastewThe plugins folder is soft linked to another location so I will need you to run this and post the /tmp/info.txt file here so we can view it.
ls -alR /usr/nagios/libexec/ >/tmp/info.txtCode: Select all
/etc/nagios/objects/commands.cfg: command_name check_zookeeper
/etc/nagios/objects/commands.cfg: command_line $USER1$/check_plugin.pl $USER1$/check_zookeeper.pl -H $HOSTADDRESS$ -P 4150Code: Select all
/etc/nagios/nagios.cfgBe sure to check out our Knowledgebase for helpful articles and solutions!
