I need to be able to trigger an alert if an O365 email account has greater than X number of unread emails in it.
Does anyone know if this can be done with Nagios XI?
Thanks!
O365 Email Message Count
npolovenko
- Support Tech
Re: O365 Email Message Count
@cnewstrom, Looks like this plugin can do what you're looking for.
https://exchange.nagios.org/directory/P ... ls/details
Feel free to check out our mail section of the Nagios Exchange, you'll likely find more plugins for Office 365:
https://exchange.nagios.org/directory/P ... -Groupware
I've checked out the check_unread_mails.pl script already.
Has anyone gotten this to work agains an O365 account?
I couldn't seem to get it going against O365 for some reason.
I'm pretty sure the issue was certificate related, but I also think the script might need some updating.
If anyone is successfully using this script I'd appreciate any tips they might lend.
Thanks!
Thanks!
npolovenko
- Support Tech
@cnewstrom, I'm not using O365 in the lab so can't test this. Looks like the author of this plugin left the link to his LinkedIn on the plugin page
You could try reaching out to him directly or even better, open a new issue on the GitHub page:
https://github.com/elio78/nagios/issues/new
I've attached a modified script that points to the correct modules. I also needed to install the CBC.pm module:
yum -y install perl-Crypt-CBC
Thanks for the help with the module.
Were you actually able to get this to run?
I'm not able to fully test since I don't have a 0365, but did correct some problems that would arise due to the script pointing at old modules.
