xi 5.4.12 event log disappeared
What a mystery. all of the xi event logs on my server have disappeared.
If I go to Admin/monitoring processes/ eventlog
and do a search from any time period nothing shows up.
Proudly running:
Nagios Network Analyser
Nagios Fusion
Nagios Fusion
npolovenko
- Support Tech
Re: xi 5.4.12 event log disappeared
Hello, @benhank. Did anyone truncate the nagios_logentries table in mysql? What's the output of:
Also, please run this command and let me know if event log entries come back.
echo "SELECT * FROM nagios_logentries;" | mysql -u root -pnagiosxi nagiosCode: Select all
echo 'repair table nagios_logentries use_frm;' | mysql -t -u root -pnagiosxi nagiosAs of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new Privacy Policy.
I ran it and got the following but the data has not returned
echo 'repair table nagios_logentries use_frm;' | m ysql -t -u root -pnagiosxi nagios
| Table | Op | Msg_type | Msg_text |
| nagios.nagios_logentries | repair | warning | Number of rows changed from 0 t o 9146 |
| nagios.nagios_logentries | repair | status | OK |
+--------------------------+--------+----------+-------------------------------- -------+You do not have the required permissions to view the files attached to this post.
Proudly running:
Nagios Fusion
Nagios Fusion
npolovenko
- Support Tech
@benhank, Please take a screenshot of the empty event log page in XI and upload it in this thread.
Could you send in your Nagios XI System Profile so I can review it?
To send us your system profile. Login to the Nagios XI GUI using a web browser.
Save the profile.zip file and send it to me in a private message.
sent =D
And no we didn't truncate anything.
Proudly running:
Nagios Fusion
Nagios Fusion
npolovenko
- Support Tech
@benhank, I'm still seeing entries related to a corrupted MySQL table.
Did you run the command I gave you on the server that hosts the offloaded database?
Please run this command a couple more times on the offloaded server:
Close the browser and reload the web page.
If this solution doesn't work, you may need to restore from a previous DB backup or restore just the logentries table. Can you show me the output of:
After that please run the following commands in order:echo 'repair table nagios_logentries use_frm;' | mysql -t -u root -pnagiosxi nagios
service crond stop
service npcd stop
service nagios stop
service ndo2db stop
pkill -9 -u nagios
for i in $(ipcs -q | grep nagios |awk '{print $2}'); do ipcrm -q $i; done
rm -rf /usr/local/nagiosxi/var/dbmaint.lock
rm -rf /usr/local/nagiosxi/var/event_handler.lock
rm -rf /usr/local/nagiosxi/scripts/reconfigure_nagios.lock
service mysqld restart
service ndo2db start
service nagios start
service npcd start
service crond startIf this solution doesn't work, you may need to restore from a previous DB backup or restore just the logentries table. Can you show me the output of:
ls -lR /store/backups/As of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new Privacy Policy.
sigh, no I didnt run it on the offloaded server, because I forgot it was offloaded, just ran it with the following results:
root@lkenfusionp01 ~]# echo 'repair table nagios_logentries use_frm;' | mysql -t -u root -pnagiosxi nagios
| nagios.nagios_logentries | repair | error | Can't create new tempfile: './nagios/nagios_logentries.TMD' |
| nagios.nagios_logentries | repair | status | Operation failed Proudly running:
Nagios Fusion
Nagios Fusion
npolovenko
- Support Tech
@benhank, Your repair command didn't work. Is the offloaded MySQL server running out of space?
Also, try moving the nagios_logentries.TMD to a backup directory and rerunning the repair command one more time:
df -hCode: Select all
mv /nagios/nagios_logentries.TMD /tmp/As of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new Privacy Policy.
yes im running it on the offloaded server (this time). The server isnt running out of space
and
/dev/mapper/vg_lkenfusiondev-lv_root
96G 14G 78G 16% /
tmpfs 7.8G 80K 7.8G 1% /dev/shm
/dev/sda1 477M 130M 322M 29% /boot
/dev/mapper/vg_lkenfusiondev-lv_home
446G 4.0G 420G 1% /home
/dev/mapper/vg_fusiondev900-lv_nagdb
413G 71M 392G 1% /nagdb
/dev/mapper/vg_fusiondev900-lv_perf
413G 71M 392G 1% /perf
[root@lkenfusionp01 nagios]#
mv: cannot stat `/nagios/nagios_logentries.TMD': No such file or directory
[root@lkenfusionp01 ~]# cd /usr/local/nagios/
[root@lkenfusionp01 nagios]# mv /nagios/nagios_logentries.TMD /tmp/
Proudly running:
Nagios Fusion
Nagios Fusion
npolovenko
- Support Tech
@benhank, Did you run the following commands I provided earlier?
And please try the following command to move the .TMD table:
You have duplicate nagios processes running and these commands should get rid of it.service crond stop
service npcd stop
service nagios stop
service ndo2db stop
pkill -9 -u nagios
service npcd start
service crond start
When done, please run the repair table command one more time. And upload the /var/log/mariadb/mariadb.log or /var/log/mysqld.log from the offloaded mysql server.mv /var/lib/mysql/nagios/nagios_logentries.TMD /tmp/
