automatic creation of pids
shivangi
Post by shivangi »
Hi Team,
I am currently working on nagios core version 4.4.1 and the problem i am facing is automatic generation of the nagios pids whenever i do any configuration changes on it as a reult of which nagios sometimes throws fake alerts , no alerts at all , missing configuration changes etc.
So everytime i have to manually kill those nagios pids in order to have nagios function properly ...
Can i know the reason for such behavior of Nagios and have a permanent solution for this so that no fake pids are generated at regular intervals .
Thanks in advance ..
Re: automatic creation of pids
What is the location of the pid files?
What is set as the
lock_file
in your nagios.cfg?
shivangi
Post by shivangi »
Thanks for your response. :)
Location of my lock file is /usr/local/Nagios/var/Nagios.lock
and whenever i do pgrep nagios | wc -l even after stopping nagios ,there are a lot of pids running (approx 100 or even more).
What OS is this running on?
Also, next time you stop nagios can you run the following so we can see what they are?
ps -ef|grep nagios
finally, how are you starting/stopping nagios (what commands do you issue)?
shivangi
Post by shivangi »
Hi Scotwilkerson,
Refer the attachment for the information on OS version and output of ps -ef| grep nagios . I hope it helps . :)
Also the commands i use for starting and stopping the nagios are :
service nagios start
service nagios stop
Thanks .
doc1.docx
(330.16 KiB) Downloaded 173 times
Is this the server running nagios? I only see NRPE checks...
let's narrow it down
ps -ef|grep nagios.cfg
shivangi
Post by shivangi »
Yes Nagios is running on this server .
Refer the Attachment for the output of ps -ef | grep Nagios.cfg.
doc1.docx
(22.83 KiB) Downloaded 191 times
What is the output of the following:
grep nagios.lock /etc/init.d/nagios
shivangi
Post by shivangi »
Hi ,
I have attached the document for the command u asked.Hope it helps :)
Thanks.
doc1.docx
(16.53 KiB) Downloaded 172 times
This all looks normal, can you describe the details of what you are seeing as a problem? I think I'm misunderstanding the actual issue.
