This support forum board is for support questions relating to
Nagios XI , our flagship commercial network monitoring solution.
LAINFOSEC
Posts: 16 Joined: Wed Feb 13, 2019 10:23 am
Post
by LAINFOSEC » Mon May 06, 2019 10:22 am
I have followed the guide for installing the PERL SDK to the NagiosXI server as well as ran the config wizard properly. I keep receiving this error under the various services status:
(Return code of 127 is out of bounds. Check if plugin exists)
+Perl SDK 6.5 and 6.7 have been attempted
+My OS is CentOS6
[root@localhost libexec]# ls -l check_vmware_api.pl
-rwxrwxr-x. 1 apache nagios 170370 Apr 22 08:05 check_vmware_api.pl
[root@localhost vmware]# perl -v |grep version
This is perl 5, version 16, subversion 3 (v5.16.3) built for x86_64-linux-thread-multi
"New technology is not good or evil in and of itself. It's all about how people choose to use it."
npolovenko
Posts: 3457 Joined: Mon May 15, 2017 5:00 pm
Post
by npolovenko » Mon May 06, 2019 12:47 pm
@LAPFCU , Please check the version of the VMWare wizard in XI and if it's below 1.7.3 please update the wizard to the latest version.
Then run the following plugin from the command line and show me the output:
/usr/local/nagios/libexec/check_vmware_api.pl
As of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new
Privacy Policy .
