NagiosIX send traps from a Hostgroup
juanmafer
Post by juanmafer »
I need the NagiosIX to send traps to another alarm System. Now I enable the "SNMP Trap Sender" component, and I am receiving traps on the external server correctly. But NagiosIX is sending traps for all the HOST and alarmas configured, is it possible to configure the nagiosIX to send traps from a certain hostgroup or Host and not from all the Hosts?
Thanks for your time,
-- Ignacio
Re: NagiosIX send traps from a Hostgroup
The ability to send traps by hostgroups, servicegroups, etc. is not available right now.
You can do some filtering by status but not by groups.
I can put in a request if you like to see if it can get added in to a future release.
