NagiosXI 5.6.1 with mod_gearman2...
vishfx
Post by vishfx »
Hi Nagios Team,
We are using NagiosXI 5.5.9 with Nagios core 4.2.4 + mod_gearman2
I see that NagiosXI 5.6.1 comes with 4.4.3 + support for mod_gearman3
Also looks like mod_gearman3 integration is still beta.
Can NagiosXI 5.6.1 be used with nagios core 4.2.4 + mod_gearman2 ? ( until mod_gearman3 release is final )
Regards,
Vish.
Re: NagiosXI 5.6.1 with mod_gearman2...
We are moving away from mod_gearman2. I would recommend that you use mod_gearman3. It is no longer a "beta" - we just forgot to update the document. BTW, I just did. The feedback on Mod Gearman 3 has been very positive but as with any new thing, just to be on a safe side, try it in a test environment first, before using it in production. Thank you!
vishfx
Post by vishfx »
That's Great !!!
Thanks, you can close this.
Regards,
Vish
vishfx wrote:That's Great !!!
Regards,
Vish
great!
Locking
