How Does NRPE Calculate Memory
mkeey
Post by mkeey »
I have the Nagios Agent installed on Linux servers. It appears that the numbers do not match (see attached screen print). How does the agent calculate memory?
Re: How Does NRPE Calculate Memory
Can you share the /usr/local/nagios/etc/nrpe/common.cfg from the remote server as well as the configuration for this service?
mkeey
Post by mkeey »
As requested...
[MYUSER@PROBLEMCHILD]:[/usr/local/nagios/etc/nrpe]# more common.cfg
### GENERIC SERVICES ###
command[check_init_service]=sudo /usr/local/nagios/libexec/check_init_service $A
RG1$
command[check_services]=/usr/local/nagios/libexec/check_services -p $ARG1$
### MISC SYSTEM METRICS ###
#command[check_users]=/usr/local/nagios/libexec/check_users -w 5 -c 10
command[check_users]=/usr/local/nagios/libexec/check_users $ARG1$
command[check_load]=/usr/local/nagios/libexec/check_load $ARG1$
command[check_swap]=/usr/local/nagios/libexec/check_swap $ARG1$
command[check_cpu_stats]=/usr/local/nagios/libexec/check_cpu_stats.sh $ARG1$
command[check_mem]=/usr/local/nagios/libexec/custom_check_mem -n $ARG1$
### SYSTEM UPDATES ###
command[check_yum]=/usr/local/nagios/libexec/check_yum
command[check_apt]=/usr/local/nagios/libexec/check_apt
### DISK ###
command[check_disk]=/usr/local/nagios/libexec/check_disk $ARG1$
command[check_ide_smart]=/usr/local/nagios/libexec/check_ide_smart $ARG1$
### PROCESSES ###
command[check_all_procs]=/usr/local/nagios/libexec/custom_check_procs
command[check_procs]=/usr/local/nagios/libexec/check_procs $ARG1$
### OPEN FILES ###
command[check_open_files]=/usr/local/nagios/libexec/check_open_files.pl $ARG1$
### NETWORK CONNECTIONS ###
command[check_netstat]=/usr/local/nagios/libexec/check_netstat.pl -p $ARG1$ $ARG
2$
Can you also share the configuration for this service in XI?
mkeey
Post by mkeey »
Sorry for the delay in responding. Can you share with me how to export the config?
mkeey wrote:Sorry for the delay in responding. Can you share with me how to export the config?
Configure -> CCM -> Services
Click on the "View Config" icon next to this service.
then find the definition for this service name
mkeey
Post by mkeey »
Sorry, didn't realize you just wanted a copy of the config file. Changed hostname & ip along with notified users for proprietary reasons.
# Services configuration file
# Created by: Nagios CCM 2.7.0
# Date: 2019-05-17 10:31:15
# Version: Nagios Core 4.x
# Nagios CCM will overwrite all manual settings during the next update if you
# would like to edit files manually, place them in the 'static' directory or
# import your configs into the CCM by placing them in the 'import' directory.
host_name REMOTESERVERNAME
service_description / Disk Usage
use xiwizard_nrpe_service
check_command check_nrpe!check_disk!-a '-w 15% -c 5% -p /'
max_check_attempts 5
check_interval 5
retry_interval 1
notification_interval 60
contacts ENDUSERS
_xiwizard linux-server
register 1
service_description /home Disk Usage
check_command check_nrpe!check_disk!-a '-w 15% -c 5% -p /home'
check_interval 5
retry_interval 1
contacts ENDUSERS
register 1
service_description /opt Disk Usage
check_command check_nrpe!check_disk!-a '-w 15% -c 5% -p /opt'
check_interval 5
retry_interval 1
contacts ENDUSERS
register 1
service_description /srv/bit9 Disk Usage
check_command check_nrpe!check_disk!-a '-w 15% -c 5% -p /srv/bit9'
check_interval 5
retry_interval 1
contacts ENDUSERS
register 1
service_description /tmp Disk Usage
check_command check_nrpe!check_disk!-a '-w 15% -c 5% -p /tmp'
check_interval 5
retry_interval 1
contacts ENDUSERS
register 1
service_description /var Disk Usage
check_command check_nrpe!check_disk!-a '-w 15% -c 5% -p /var'
check_interval 5
retry_interval 1
contacts ENDUSERS
register 1
service_description /var/log Disk Usage
check_command check_nrpe!check_disk!-a '-w 15% -c 5% -p /var/log'
check_interval 5
retry_interval 1
contacts ENDUSERS
register 1
service_description CPU Stats
check_command check_nrpe!check_cpu_stats!-a '-w 90 -c 95'
max_check_attempts 20
check_interval 5
retry_interval 3
notification_options n
notifications_enabled 0
contacts ENDUSERS
register 1
service_description Memory Usage
check_command check_nrpe!check_mem!-a '-w 10 -c 5'
max_check_attempts 24
check_interval 10
retry_interval 5
contacts ENDUSERS
register 1
service_description Ping
use xiwizard_linuxserver_ping_service
check_interval 5
retry_interval 1
contacts ENDUSERS
register 1
service_description Users
check_command check_nrpe!check_users!-a '-w 10 -c 20'
check_interval 5
retry_interval 1
notification_interval 0
notifications_enabled 1
contacts ENDUSERS
register 1
# END OF FILE
this all looks correct.
I'm looking at your first post and what do you not think is correct?
The server has 43082744 bytes memory, which is 42072 MB
43082744 / 1024 = 42072.9921875
mkeey
Post by mkeey »
Thanks Scott... I will forward to my Linux Admin who was questioning this. I will get back to you.
mkeey wrote:Thanks Scott... I will forward to my Linux Admin who was questioning this. I will get back to you.
Sounds good
