For example:
PHP Notice: Undefined variable: class in /usr/local/nagiosxi/html/includes/components/nocscreen/nocscreenapi.php on line 425
I confirmed that "display_errors = Off" is in /etc/php.ini.
Is there any other way to stop these messages?
I also have the spinning "Update in progress".
Nagios XI version: 5.6.1
CentOS release 6.10 (Final)
PHP Version: 5.3.3
Operations Center spamming logs with PHP Undefined variable
benjaminsmith
Re: Operations Center spamming logs with PHP Undefined varia
Hello @rpike,
This is a known issue with upgrades that should be resolved in a later release. However, if you can stop the page, then run the upgrade from the command line instead:
and let me know if you able to successfully upgrade. As far as the notices, try to set display_errors = 0 and then re-start Apache.
wget -O upgrade.sh https://assets.nagios.com/downloads/nagiosxi/upgrade.sh
sh ./upgrade.sh
service httpd restartAs of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new Privacy Policy.
