I'm wondering if there is a way to clear multiple acknowledgements, we probably have a few thousand old ones that we'd like to clear. I saw a topic from 2012 on it but nothing since.
Clear multiple acknowledgements
Re: Clear multiple acknowledgements
Check for the mass acknowledge feature under Home > Incident Management and it looks like it's been around for a bit - https://labs.nagios.com/2014/01/29/usin ... nagios-xi/.
Thanks but I want to clear the acknowledgements instead of creating new ones. I haven't quite found a way and not sure if it is possible
Ah. Looks like I read that a bit wrong. There are some tools on the exchange that can help remove older comments:
https://exchange.nagios.org/directory/A ... ledgements
