we are able to telnet 5666 port but NRPE not responding.
Please help to resolve the issue.
nrpe communication issue
progressive.nagiosXI
Re: nrpe communication issue
Most probably, there is a mismatch between the NRPE version that is used on the remote machine, and the the one used on the Nagios XI server.
Can you run the following commands from the command line on the Nagios XI server, and show the output?
/usr/local/nagios/libexec/check_nrpe -H <client ip>
/usr/local/nagios/libexec/check_nrpe -2 -H <client ip>Be sure to check out our Knowledgebase for helpful articles and solutions!
Client IP
[root@monitoring-nagiosxi ~]# /usr/local/nagios/libexec/check_nrpe -H 13.71.*.*
NRPE v2.15
[root@monitoring-nagiosxi ~]# /usr/local/nagios/libexec/check_nrpe -2 -H 13.71.*.*
NRPE v2.15
Nagiosxi
[root@monitoring-nagiosxi libexec]# ./check_nrpe -V
NRPE Plugin for Nagios
Version: 3.2.1
Client IP
NRPE v2.15
NRPE v2.15
Nagiosxi
Version: 3.2.1
I would recommend upgrading NRPE version on the client machine by following the steps, outlined in the KB article below:
https://support.nagios.com/kb/article/n ... e-520.html
If you don't want to upgrade your agent at this time, you could try modifying your commands by including "-2". This should fix the issue with the different versions of NRPE used on the server and the client.
Example:
Example:
/usr/local/nagios/libexec/check_nrpe -2 -H x.x.x.x -c check_users -a '-w 2 -c 5'
USERS OK - 1 users currently logged in |users=1;2;5;0
still issue not resolved
# /usr/local/nagios/libexec/check_nrpe -2 -H 13.71.*.* -c check_users -a '-w 2 -c 5'
CHECK_NRPE: Receive header underflow - only 0 bytes received (4 expected).
Do you have the following line in the nrpe.cfg file on the remote machine?
If the value is "0", change it to "1", save, exit, and restart the NRPE daemon on the remote box.
Test your check from the CLI again. If it is still failing, set up a new one on the remote machine, with "hard-coded" arguments (for testing purposes), for example:
Save, exit, and restart NRPE. Next, try the following commands from the Nagios XI server:
Did any of these work?
dont_blame_nrpe=1Test your check from the CLI again. If it is still failing, set up a new one on the remote machine, with "hard-coded" arguments (for testing purposes), for example:
command[check_users_noargs]=/usr/local/nagios/libexec/check_users -w 2 -c 5Code: Select all
/usr/local/nagios/libexec/check_nrpe -H <client ip> -c check_users_noargs
/usr/local/nagios/libexec/check_nrpe -H <client ip> -2 -c check_users_noargsBe sure to check out our Knowledgebase for helpful articles and solutions!
