Network Design
kakomaisa
Network Design
Post by kakomaisa »
Hi
I finished adding all my servers and routers .
I need to do network design for the information's I put , how can I do that .
Re: Network Design
Are you referring to adding parent hosts so that they show up correctly in the network maps?
kakomaisa
Re: Network Design
Post by kakomaisa »
Hi
Yes iam referring to adding parent hosts so that they show up on the map .
Re: Network Design
Ok, you can add a hosts parent by going to Configure -> CCM -> Hosts
Select host you want to add a parent for
Click Manage Parents
Select the parent of this host
Click Close
Save
Apply configuration
kakomaisa
Re: Network Design
Post by kakomaisa »
Hi
Click Close
Save
Apply configuration
I selected the host but iam not seeing manage parents , can you guide me on where to find it .
Re: Network Design
By select host I meant click the Edit icon under Actions column or click on the linked hostname
kakomaisa
Re: Network Design
Post by kakomaisa »
Hi
I did all of that , now where can I find the design or layout of the network that I added .
Re: Network Design
Under Home -> Maps -> Hypermap
