VMWare 6.5 not compatibility.
dimsum
Post by dimsum »
I have installed a plugin for VMware everything is work for 6.0 but when I connect to VMWare 6.5 I got the error see my attached.
Any idea,
Thank you.
Re: VMWare 6.5 not compatibility.
Did you follow the document below, while installing the SDK?
Did you see the "Enjoy --the VMware team" at the end of the install? Did you see notices about old perl modules that need to be upgraded? Have you tried upgrading these perl modules?
Can you show us an actual check (that is failing), run from the command line along with the output of it?
