I had this output from script.
[root@localhost ~]# /usr/bin/cfgmaker --show-op-down --noreversedns --zero-speed '100000000' '[email protected]::::2'
Subroutine SNMP_Session::pack_sockaddr_in6 redefined at /usr/share/perl5/vendor_perl/Exporter.pm line 66.
at /usr/bin/../lib/mrtg2/SNMP_Session.pm line 149.
Subroutine SNMP_Session::unpack_sockaddr_in6 redefined at /usr/share/perl5/vendor_perl/Exporter.pm line 66.
Subroutine SNMPv1_Session::pack_sockaddr_in6 redefined at /usr/share/perl5/vendor_perl/Exporter.pm line 66.
at /usr/bin/../lib/mrtg2/SNMP_Session.pm line 604.
Subroutine SNMPv1_Session::unpack_sockaddr_in6 redefined at /usr/share/perl5/vendor_perl/Exporter.pm line 66.
--base: Get Device Info on [email protected]::::2
SNMP Error:
no response received
SNMPv2c_Session (remote host: "xx.xx.xx.xxx" [xx.xx.xx.xxx].161)
community: "xxxxxxxxx"
request ID: -828782832
PDU bufsize: 8000 bytes
timeout: 2s
retries: 5
backoff: 1)
at /usr/bin/../lib/mrtg2/SNMP_util.pm line 651.
SNMPWALK Problem for 1.3.6.1.2.1.1 on [email protected]::::2:v4only
at /usr/bin/cfgmaker line 951.
WARNING: Skipping [email protected]:161::::2 as no info could be retrieved
Use of uninitialized value $comment_sysdescr in substitution (s///) at /usr/bin/cfgmaker line 379.
Use of uninitialized value $sysname in concatenation (.) or string at /usr/bin/cfgmaker line 412.
Use of uninitialized value $comment_sysdescr in concatenation (.) or string at /usr/bin/cfgmaker line 412.
Use of uninitialized value $syscontact in concatenation (.) or string at /usr/bin/cfgmaker line 412.
Use of uninitialized value $syslocation in concatenation (.) or string at /usr/bin/cfgmaker line 412.
# Created by
# /usr/bin/cfgmaker --show-op-down --noreversedns --zero-speed 100000000 [email protected]::::2
### Global Config Options
# for UNIX
# WorkDir: /home/http/mrtg
# or for NT
# WorkDir: c:\mrtgdata
### Global Defaults
# to get bits instead of bytes and graphs growing to the right
# Options[_]: growright, bits
EnableIPv6: no
# System:
# Description:
# Contact:
# Location:
I cannot add my one of the switch
Re: I cannot add my one of the switch
The error displayed suggests that the device is not enabled to be polled by SNMP, the community string is incorrect, or if it is enabled, it might not be configured to allow the SNMP OID that cfgmaker needs to be polled.
Lets run a snmpwalk command to see if you can get any response from the device. Replace xxx.xxx.xxx.xxx with the IP address and yyyyyyyyy with the community string.
What is the Make and model number of the device you are trying to setup?
snmpwalk xxx.xxx.xxx.xxx -c yyyyyyyyy -v 2cBe sure to check out our Knowledgebase for helpful articles and solutions!
