hi guys
i have a problem with the check.. when i execute in the terminal with user root all is fine.. but when i tried run with nagios user
give me the error "CRITICAL - could not load perl module DBD::Sybase"
i join the nagios user to root group, but nothing :/
Problem with check_mssql-health
Re: Problem with check_mssql-health
You need to make sure that the DBD::Sybase perl module is installed globally and not just in a cpan dir under /root
blasthunter
thanks bro!
no problemblasthunter wrote:thanks bro!
