nagios.cfg (code=exited, status=1/FAILURE)
aesir223
Post by aesir223 »
Unable to start Nagios (4.4.3) running on Ubuntu 18.04.2 LTS.
I would appreciate any help.
Errors Below
When starting the service
Job for nagios.service failed because the control process exited with error code.
See "systemctl status nagios.service" and "journalctl -xe" for details.
When running journalctl -xe
May 16 18:58:04 tasia nagios[11318]: Checked 1 contact groups.
May 16 18:58:04 tasia nagios[11318]: Checked 24 commands.
May 16 18:58:04 tasia nagios[11318]: Checked 5 time periods.
May 16 18:58:04 tasia nagios[11318]: Checked 0 host escalations.
May 16 18:58:04 tasia nagios[11318]: Checked 0 service escalations.
May 16 18:58:04 tasia nagios[11318]: Checking for circular paths...
May 16 18:58:04 tasia nagios[11318]: Checked 12 hosts
May 16 18:58:04 tasia nagios[11318]: Checked 0 service dependencies
May 16 18:58:04 tasia nagios[11318]: Checked 0 host dependencies
May 16 18:58:04 tasia nagios[11318]: Checked 5 timeperiods
May 16 18:58:04 tasia nagios[11318]: Checking global event handlers...
May 16 18:58:04 tasia nagios[11318]: Checking obsessive compulsive processor commands...
May 16 18:58:04 tasia nagios[11318]: Checking misc settings...
May 16 18:58:04 tasia nagios[11318]: Total Warnings: 0
May 16 18:58:04 tasia nagios[11318]: Total Errors: 12
May 16 18:58:04 tasia nagios[11318]: ***> One or more problems was encountered while running the pre-flight check...
May 16 18:58:04 tasia nagios[11318]: Check your configuration file(s) to ensure that they contain valid
May 16 18:58:04 tasia nagios[11318]: directives and data definitions. If you are upgrading from a previous
May 16 18:58:04 tasia nagios[11318]: version of Nagios, you should be aware that some variables/definitions
May 16 18:58:04 tasia nagios[11318]: may have been removed or modified in this version. Make sure to read
May 16 18:58:04 tasia nagios[11318]: the HTML documentation regarding the config files, as well as the
May 16 18:58:04 tasia nagios[11318]: 'Whats New' section to find out what has changed.
May 16 18:58:04 tasia systemd[1]: nagios.service: Control process exited, code=exited status=1
May 16 18:58:04 tasia systemd[1]: nagios.service: Failed with result 'exit-code'.
May 16 18:58:04 tasia systemd[1]: Failed to start Nagios Core 4.4.3.
-- Subject: Unit nagios.service has failed
-- Defined-By: systemd
-- Support: http://www.ubuntu.com/support
-- Unit nagios.service has failed.
-- The result is RESULT.
When running systemctl status nagios.service
May 16 18:59:10 tasia nagios[11406]: ***> One or more problems was encountered while running the pre-flight check...
May 16 18:59:10 tasia nagios[11406]: Check your configuration file(s) to ensure that they contain valid
May 16 18:59:10 tasia nagios[11406]: directives and data definitions. If you are upgrading from a previous
May 16 18:59:10 tasia nagios[11406]: version of Nagios, you should be aware that some variables/definitions
May 16 18:59:10 tasia nagios[11406]: may have been removed or modified in this version. Make sure to read
May 16 18:59:10 tasia nagios[11406]: the HTML documentation regarding the config files, as well as the
May 16 18:59:10 tasia nagios[11406]: 'Whats New' section to find out what has changed.
May 16 18:59:10 tasia systemd[1]: nagios.service: Control process exited, code=exited status=1
May 16 18:59:10 tasia systemd[1]: nagios.service: Failed with result 'exit-code'.
May 16 18:59:10 tasia systemd[1]: Failed to start Nagios Core 4.4.3.
Re: nagios.cfg (code=exited, status=1/FAILURE)
you have 12 errors in your configuration files
Did you verify your configuration before trying to restart nagios?
/path/to/bin/nagios -v /path/to/nagios.cfg
