Nagios BPI Plugin no Settings
drakeu
Post by drakeu »
I have installed the Nagios BPI Component following the "Using Nagios BPI" Instructions. I uploaded the .zip file through the Nagiosxi Coponoment Managment Interface. It shows the component as installing successfully, and the copononement shows up. However, the settings button is missing from the Manage Components screen. There is only the save or delete actions available under "actions" (I've attached a screenshot). Please advise. Thanks!
mguthrie
Re: Nagios BPI Plugin no Settings
Post by mguthrie »
I'll follow up with this by email. You're using the 1.x version of BPI with the 2x version instructions ; )
leens
Post by leens »
Hello
I've same problem. Is it possible to have a version of NAgios BPI 2.x? Where can we download?
mguthrie
Post by mguthrie »
Just sent you an email with the beta component and wizard : )
[EDIT]: Correction, your email server doesn't like the zips, I'll send them in a PM.
leens
Post by leens »
thanks!!!
