With the latest upgrade Goggle Map menu item is missing from the Maps section of the Home. Is it moved somewhere? How can I bring it back?
Regards!
NJ
Google Map missing
npolovenko
- Support Tech
Re: Google Map missing
Hi, @smersh. I confirmed this bug and notified the Dev team.
Here's the fix. Please go to the Admin menu in XI, then click on the Components menu in the left column. Delete the old Google Map component and upload the new .zip attached here.
Could you please describe what needs to be altered in the google map component? We are using a highly modified version, so do we need to apply fixes or this is a problem of the XI itself?
npolovenko
- Support Tech
@smersh, I'm going to PM you the changes you need to make to the existing component to get it to work.
