hi,
after my upgrade from 5.5.7 to 5.6.1 i've deleted hosts/services but they still show up in the OPS screen/OPS center. The .cfg files is gone from /etc/hosts.
Im not sure how to remove. Ive tried recreating the host then deleting again but had the same results.
Deleted Hosts Still Showing In OPS Screen and OPS Center
benjaminsmith
Re: Deleted Hosts Still Showing In OPS Screen and OPS Center
Hi @blariv,
I just tried to repeat this and my 5.6.1 server is working as expected.
1. Did you apply configuration after deleting the hosts? Are there any configuration errors that would force a roll back to a previous configuration?
2. Try to clear your browser cache and re-load the page.
If the problem persists, run the following tail command and then load the Operations Center page again and post the output.
tail -f /var/log/httpd/*error_log
hi, thanks for the reply. I started having other weird performance and command subsystem errors as well. I just restore from a backup and we are good. I will look to upgrade at a later time.
you can lock this and thank you.
benjaminsmith
Hi @blariv,
Thank you for using the Nagios Support Forum.
Great. Happy to hear this is resolved for you.you can lock this and thank you.
