Hey everyone,
I am looking for a way to have Nagios gather certain log files instead of just "system" logs it thinks are important.
Is there a setting somewhere, maybe in the "rsyslog.conf"?
I want to be able to gather logs for applications as well, such as
NextCloud
apache2 (without using the special addon)
Redis
RabbitMQ
Is this something Nagios can do?
Can I tell Nagios to gather all logs from /var/log/*?
How to direct Nagios to gather certain log files
bkeating178
Re: How to direct Nagios to gather certain log files
There are instructions in Log Server of you go to "Add Log Source" then in the "File Monitoring" section
bkeating178
Thanks for that,
When I go through that process, I am presented with a new error, any Idea why I might be getting this?
Run the command "rsyslogd -N 1" to get some details about why it may fail. Please provide a copy of the rsyslog.conf and 90-nagioslogserver_mnt_data_nextcloud.log.conf if you're unable to resolve with the help of the output.
