NagiosXI 5.5.9 - service template import issue ...
vishfx
Post by vishfx »
Hi Nagios Team,
Am using NagiosXI 5.5.9 with Nagios Core 4.2.4 + modgearman2
Facing strange issue while importing service template by:
placing it in /usr/local/nagios/etc/import/
running /usr/local/nagiosxi/scripts/reconfigure_nagios.sh
I see that in one of the NagiosXI instance , the import is not proper and is inserting max_attempts, check_interval, retry_interval, or notification_interval values.
The same template import seems to be proper in another NagiosXI instance.
Due to this am seeing the below error:
[color=#FF0000]
Error: Invalid max_attempts, check_interval, retry_interval, or notification_interval value for service 'Check Test AUTH Node1' on host 'iaminttst01.isus.emc.com'
Error: Could not register service (config file '/usr/local/nagios/etc/services/lemc-non-prod-layer7.cfg', starting on line 86)
[/color]
PFA screenshot depicting the issue.
How can I edit/modify the template to remove max_attempts, check_interval, retry_interval, notification_interval value ?
Kindly assist.
Regards,
Vish.
Re: NagiosXI 5.5.9 - service template import issue ...
Go into the CCM Services and edit this service and on the check settings tab remove the 0 from these values
vishfx
Post by vishfx »
scottwilkerson wrote:Go into the CCM Services and edit this service and on the check settings tab remove the 0 from these values
Thanks Scott, that worked.
But, why would the import behavior vary in both NagiosXI instances ?
Regards,
Vish.
It's hard to say, did the one that didn't work already have the template created with the bad values?
It's really difficult to say conclusively because I don't know the state of each before the import.
