CCM : reverting Changes before Applying Configuration
hoegh
Post by hoegh »
Hi Team,
Unfortunately, Sometimes we end up with deleting important config Host/Service in CCM,
In this case, if I've not applied configurations, then is it possible for me to revert deleted Host/Service ? As I've not Applied any configuration changes yet.
  • Incident happened with me:
    1. I've deleted one host [host XY] unknowingly. [Don't know how it got deleted, whereas there are Services in dependencies]
    2. Now, when i entered CCM next time, It's asking me to Apply config changes made Previously.
    3. Since Dependencies are not resolved, So Apply Config throws error, That service group x has not able to find host XY, [as it is deleted in step 1]
    4. Since, I've not Committed CCM changes by Apply Configuration options.
    5. So, here i expect, the Changes [deletion of host XY] should get reverted.
I hope i made my query clear :|
Hoegh
Höegh
Re: CCM : reverting Changes before Applying Configuration
Yes.
Configure -> CCM -> Configuration Snapshots
Select the latest good configuration and click the "restore" icon
Click Ok
The CCM DB will be restore to the point where it was at the time of the last successful Apply Configuration
hoegh
Post by hoegh »
Thanks @scottwilkerson.
I was not knowing this.
Thanks for your help. Please close this thread.
Regards,
Hoegh
Höegh
hoegh wrote:Thanks @scottwilkerson.
Regards,
Hoegh
Great!
Closing
