See all hosts/services with active checks disabled
hbouma
Post by hbouma »
Is there a way to check from the command line for all hosts/services disabled? For instance, if someone were to turn off active checks from the Advanced option in the gui, can I pull a list of those checks?
This would be for Nagios XI 5.6.1 on Red Hat 7.6 64bit VM's.
Re: See all hosts/services with active checks disabled
Let's see, I know you can see them in the GUI here
Services
/nagiosxi/includes/components/xicore/status.php?show=services&serviceattr=16
Hosts
/nagiosxi/includes/components/xicore/status.php?show=hosts&hostattr=16
From the CLI you would need to grab them from the API
Services
http://YOUR_HOST/nagiosxi/api/v1/objects/servicestatus?apikey=API_KEY&pretty=1&active_checks_enabled=0
Hosts
http://YOUR_HOST/nagiosxi/api/v1/objects/hoststatus?apikey=API_KEY&pretty=1&active_checks_enabled=0
hbouma
Post by hbouma »
Thank you, this resolved my issue. please feel free to close the post.
hbouma wrote:Thank you, this resolved my issue. please feel free to close the post.
Great!
Locking
