Change IP on XI server, services disappear.
IronWolve
Post by IronWolve »
I'm replacing core servers with XI, and when I re-ip the new XI server and reboot, the services disappear.
The services are still in the database, I see they are still written to the cfg files. They just dont show on screen under services.
I have to re-ip the new server for hosts allow for nrpe/nsclient access list.
Very strange, I change the IP of the XI server back to its temp IP, and services show back up.
Re: Change IP on XI server, services disappear.
is localhost pointing to an IP in /etc/hosts?
Do you have custom IP setup for the databases in config.inc.php ? how about the ndo2db.cfg ?
Also, did you change the IP under Admin -> System Settings in the Web UI?
