Is there some issue going on with the Capacity Planning button? All the other report generation buttons are clickable but the capacity planning button is not clickable? See attached.
Thanks.
Capacity Planning Button
- jjeremydiaz
Re: Capacity Planning Button
Do you have the enterprise trial enabled? Is it expired? Please go to Admin > License Information and show us a screenshot, the capacity and SLA reports (among other things) are enterprise license only, see here for the diffs:
https://www.nagios.com/products/nagios- ... omparison/
- jjeremydiaz
Hi ssax,
Yes the enterprise trial is enabled and not expired. See attached snapshot.
Thanks for the help!
benjaminsmith
Hi Jeremy,
Which version of Nagios XI are you currently on? I just tested this on the latest version using the trial license and the it's working as expected.
