high memory usage and swapping
benhank
Post by benhank »
my server has 32gb of memory but its experiencing high memory usage and this is causing a ton of swapping on the system:
62500 	nagios 	38.19 GB 	/usr/bin/java -Xms16035m -Xmx16035m -Djava.awt.headless=true -XX:+UseParNewGC -X ...
also i am getting these errors:
usr/bin/java -Xms16035m -Xmx16035m -Djava.awt.headless=true -XX:+UseParNewGC -XX:+UseConcMarkSweepGC -XX:CMSInitiatingOccupancyFraction=75 -XX:+UseCMSInitiatingOccupancyOnly -XX:+HeapDumpOnOutOfMemoryError -XX:+DisableExplicitGC -Dfile.encoding=UTF-8 -Des.cluster.name=c9dc126e-346d-4bfa-a30e-14b849c50ab5 -Des.node.name=4832fc3b-a2d4-429c-80f1-60f23afa08c3 -Des.discovery.zen.ping.unicast.hosts=172.22.3.187,172.22.3.15,172.22.2.123 -Des.path.repo=/ -Delasticsearch -Des.pidfile=/var/run/elasticsearch/elasticsearch.pid -Des.path.home=/usr/local/nagioslogserver/elasticsearch -cp :/usr/local/nagioslogserver/elasticsearch/lib/elasticsearch-1.7.6.jar:/usr/local/nagioslogserver/elasticsearch/lib/*:/usr/local/nagioslogserver/elasticsearch/lib/sigar/* -Des.default.path.home=/usr/local/nagioslogserver/elasticsearch -Des.default.path.logs=/var/log/elasticsearch -Des.default.path.data=/usr/local/nagioslogserver/elasticsearch/data -Des.default.path.work=/usr/local/nagioslogserver/tmp/elasticsearch -Des.default.path.conf=/usr/local/nagioslogserver/elasticsearch/config org.elasticsearch.bootstrap.Elasticsearch
Im having the issues on two separate servers
Proudly running:
Nagios Network Analyser
Nagios Fusion
benhank
Re: high memory usage and swapping
Post by benhank »
guys you are already looking into this so you can lock it
Proudly running:
Nagios Fusion
benjaminsmith
Post by benjaminsmith »
Thanks Ben! We'll close this out.
