Hi!
One of my devices shows "No Data Available". I went through the steps of help-article 32 but its still not working.
I do receive flow-data in /flows directory and permissions are looking fine, nfcapd is running.
One thing I notice is, that the bandwidth.rrd "last modified timestamp" does not change (it's always the creation date) - whereas on other devices its updating.
Any ideas?
Kind Regards,
Stefan
No Data Available
Re: No Data Available
Please post the output of this command, need to make sure the capture is running:
ps aux | grep nfRe: No Data Available
Additionally, what type of device is it? Is it sflow or nflow?
Hi!
I can see the capture for the device:
nna 6026 0.0 0.0 22404 2620 ? S Mai27 0:02 /usr/local/bin nfcapd -I 15 -l /usr/local/nagiosna/var/SW_DIST1/flows -p 9920 -x /usr/local/nag iosna/bin/reap_files.py %d %f %i -P /usr/local/nagiosna/var/SW_DIST1/9920.pid -D -e -w -z -T all
nna 6027 0.0 0.0 11120 880 ? S Mai27 0:11 /usr/local/bin nfcapd -I 15 -l /usr/local/nagiosna/var/SW_DIST1/flows -p 9920 -x /usr/local/nag iosna/bin/reap_files.py %d %f %i -P /usr/local/nagiosna/var/SW_DIST1/9920.pid -D -e -w -z -T all
It's a netflow-device (Cisco 3650)
Best Regards
Best Regards
Login to the NNA server as root, run the following commands and post the /tmp/info.txt file here.
Can you login to the Cisco device, get the configuration settings from it and post it here?
It could be an configuration error that is causing it.
chage -l nna >/tmp/info.txt
grep nna /etc/group >>/tmp/info.txt
ps -ef --cols=300 >>/tmp/info.txt
ls -lR /usr/local/nagiosna/ >>/tmp/info.txtIt could be an configuration error that is causing it.
