elasticsearch service exited
Sampath.Basireddy
Post by Sampath.Basireddy »
Elasticsearch service is in active (exited) state and won't start even after stop and start.
Here is the output of service status:
[root@nagiosls1 knapsack]# systemctl status elasticsearch.service
● elasticsearch.service - LSB: This service manages the elasticsearch daemon
   Loaded: loaded (/etc/rc.d/init.d/elasticsearch; bad; vendor preset: disabled)
   Active: active (exited) (Result: exit-code) since Wed 2019-05-29 08:24:20 EDT; 24min ago
     Docs: man:systemd-sysv-generator(8)
  Process: 1206 ExecStop=/etc/rc.d/init.d/elasticsearch stop (code=exited, status=0/SUCCESS)
  Process: 1319 ExecReload=/etc/rc.d/init.d/elasticsearch reload (code=exited, status=7)
  Process: 1214 ExecStart=/etc/rc.d/init.d/elasticsearch start (code=exited, status=0/SUCCESS)
May 29 08:24:20 nagiosls1.ux.corp.local systemd[1]: Started LSB: This service manages the elasticsearch daemon.
May 29 08:24:20 nagiosls1.ux.corp.local elasticsearch[1214]: OpenJDK 64-Bit Server VM warning: INFO: os::commit_memory(0x00000002e9990...no=12)
May 29 08:24:20 nagiosls1.ux.corp.local elasticsearch[1214]: #
May 29 08:24:20 nagiosls1.ux.corp.local elasticsearch[1214]: # There is insufficient memory for the Java Runtime Environment to continue.
May 29 08:24:20 nagiosls1.ux.corp.local elasticsearch[1214]: # Native memory allocation (mmap) failed to map 20776943616 bytes for com...emory.
May 29 08:24:20 nagiosls1.ux.corp.local elasticsearch[1214]: # An error report file with more information is saved as:
May 29 08:24:20 nagiosls1.ux.corp.local elasticsearch[1214]: # /tmp/hs_err_pid1239.log
May 29 08:24:30 nagiosls1.ux.corp.local systemd[1]: Reloading LSB: This service manages the elasticsearch daemon.
May 29 08:24:30 nagiosls1.ux.corp.local systemd[1]: elasticsearch.service: control process exited, code=exited status=7
May 29 08:24:30 nagiosls1.ux.corp.local systemd[1]: Reload failed for LSB: This service manages the elasticsearch daemon.
Hint: Some lines were ellipsized, use -l to show in full.
It says "There is insufficient memory for the Java Runtime Environment to continue.", but I see free memory available on the server:
[root@nagiosls1 /]# free -m
              total        used        free      shared  buff/cache   available
Mem:          32173       22642        4316          33        5214        9049
Swap:          3999        1907        2092
top - 08:54:42 up 26 days, 13:00,  2 users,  load average: 0.12, 0.12, 0.18
Tasks: 271 total,   1 running, 270 sleeping,   0 stopped,   0 zombie
%Cpu(s):  0.2 us,  0.1 sy,  0.4 ni, 99.2 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
KiB Mem : 32946004 total,  4413728 free, 23192152 used,  5340124 buff/cache
KiB Swap:  4095996 total,  2142840 free,  1953156 used.  9261048 avail Mem
Please suggest.
Re: elasticsearch service exited
Something on this server is using a lot of memory, and elasticsearch requires the use of over 50% of the systems memory.
Can you show the output of the following
ps -eo pmem,pcpu,vsize,pid,cmd | sort -k 1 -nr | head -10
Sampath.Basireddy
I totally forgot I create this topic, and also did not see this issue for almost week after rebooting the server.
Since this morning elasticsearch started going in exited state very frequently and it comes back up after restart.
Here is the output you asked for:
[root@nagiosls1 ~]# ps -eo pmem,pcpu,vsize,pid,cmd | sort -k 1 -nr | head -10
66.3  174 52219020 18913 /bin/java -Xms20480m -Xmx20480m -Djava.awt.headless=true -XX:+UseParNewGC -XX:+UseConcMarkSweepGC -XX:CMSInitiatingOccupancyFraction=75 -XX:+UseCMSInitiatingOccupancyOnly -XX:+HeapDumpOnOutOfMemoryError -XX:+DisableExplicitGC -Dfile.encoding=UTF-8 -Des.cluster.name=92ab601c-2645-49fa-98ab-52d987a0a647 -Des.node.name=745e0cf8-855b-48c9-91c0-3973b12ae3bf -Des.discovery.zen.ping.unicast.hosts=10.10.24.65 -Des.path.repo=/ -Delasticsearch -Des.pidfile=/var/run/elasticsearch/elasticsearch.pid -Des.path.home=/usr/local/nagioslogserver/elasticsearch -cp :/usr/local/nagioslogserver/elasticsearch/lib/elasticsearch-1.7.6.jar:/usr/local/nagioslogserver/elasticsearch/lib/*:/usr/local/nagioslogserver/elasticsearch/lib/sigar/* -Des.default.path.home=/usr/local/nagioslogserver/elasticsearch -Des.default.path.logs=/var/log/elasticsearch -Des.default.path.data=/usr/local/nagioslogserver/elasticsearch/data -Des.default.path.work=/usr/local/nagioslogserver/tmp/elasticsearch -Des.default.path.conf=/usr/local/nagioslogserver/elasticsearch/config org.elasticsearch.bootstrap.Elasticsearch
 1.9 63.5 9663652 17447 /bin/java -XX:+UseParNewGC -XX:+UseConcMarkSweepGC -Djava.awt.headless=true -XX:CMSInitiatingOccupancyFraction=75 -XX:+UseCMSInitiatingOccupancyOnly -XX:+HeapDumpOnOutOfMemoryError -Djava.io.tmpdir=/usr/local/nagioslogserver/tmp -Xmx1024m -Xss2048k -Djffi.boot.library.path=/usr/local/nagioslogserver/logstash/vendor/jruby/lib/jni -XX:+UseParNewGC -XX:+UseConcMarkSweepGC -Djava.awt.headless=true -XX:CMSInitiatingOccupancyFraction=75 -XX:+UseCMSInitiatingOccupancyOnly -XX:+HeapDumpOnOutOfMemoryError -Djava.io.tmpdir=/usr/local/nagioslogserver/tmp -XX:HeapDumpPath=/usr/local/nagioslogserver/logstash/heapdump.hprof -Xbootclasspath/a:/usr/local/nagioslogserver/logstash/vendor/jruby/lib/jruby.jar -classpath : -Djruby.home=/usr/local/nagioslogserver/logstash/vendor/jruby -Djruby.lib=/usr/local/nagioslogserver/logstash/vendor/jruby/lib -Djruby.script=jruby -Djruby.shell=/bin/sh org.jruby.Main --1.9 /usr/local/nagioslogserver/logstash/lib/bootstrap/environment.rb logstash/runner.rb agent -f /usr/local/nagioslogserver/logstash/etc/conf.d -l /var/log/logstash/logstash.log -w 4
 0.1  0.0 252724  7105 /usr/bin/ruby /usr/bin/puppet agent  --no-daemonize
%MEM %CPU    VSZ   PID CMD
 0.0  3.8 296388 25165 /usr/bin/php -q /var/www/html/nagioslogserver/www/index.php jobs
 0.0  2.0 294808 25166 /usr/bin/php -q /var/www/html/nagioslogserver/www/index.php poller
 0.0  1.9      0 14102 [kworker/0:1]
 0.0 11.4 844792  8420 /opt/rapid7/ir_agent/components/insight_agent/2.6.5.8/ir_agent --multiprocessing-fork pipe_handle=18 tracker_fd=14
 0.0  0.6      0    65 [kswapd0]
 0.0  0.5 212308 25162 /usr/sbin/CROND -n
Could you send like the last 50-100 lines of /var/log/elasticsearch/92ab601c-2645-49fa-98ab-52d987a0a647.log to see what is causing ES to stop?
Is this on a VM that could have over-allocated memory on an ESX server for example?
Sampath.Basireddy
Elasticsearch was exited few mins back. I stopped and started and below are 200 lines after restarting the service:
[root@nagiosls1 ~]# tail -200 /var/log/elasticsearch/92ab601c-2645-49fa-98ab-52d987a0a647.log
	at org.elasticsearch.common.netty.handler.codec.http.HttpContentDecoder.messageReceived(HttpContentDecoder.java:108)
	at org.elasticsearch.common.netty.channel.SimpleChannelUpstreamHandler.handleUpstream(SimpleChannelUpstreamHandler.java:70)
	at org.elasticsearch.common.netty.channel.DefaultChannelPipeline.sendUpstream(DefaultChannelPipeline.java:564)
	at org.elasticsearch.common.netty.channel.DefaultChannelPipeline$DefaultChannelHandlerContext.sendUpstream(DefaultChannelPipeline.java:791)
	at org.elasticsearch.common.netty.channel.Channels.fireMessageReceived(Channels.java:296)
	at org.elasticsearch.common.netty.handler.codec.frame.FrameDecoder.unfoldAndFireMessageReceived(FrameDecoder.java:459)
	at org.elasticsearch.common.netty.handler.codec.replay.ReplayingDecoder.callDecode(ReplayingDecoder.java:536)
	at org.elasticsearch.common.netty.handler.codec.replay.ReplayingDecoder.messageReceived(ReplayingDecoder.java:435)
	at org.elasticsearch.common.netty.OpenChannelsHandler.handleUpstream(OpenChannelsHandler.java:74)
	at org.elasticsearch.common.netty.channel.DefaultChannelPipeline.sendUpstream(DefaultChannelPipeline.java:559)
	at org.elasticsearch.common.netty.channel.Channels.fireMessageReceived(Channels.java:268)
	at org.elasticsearch.common.netty.channel.Channels.fireMessageReceived(Channels.java:255)
	at org.elasticsearch.common.netty.channel.socket.nio.NioWorker.read(NioWorker.java:88)
	at org.elasticsearch.common.netty.channel.socket.nio.AbstractNioWorker.process(AbstractNioWorker.java:108)
	at org.elasticsearch.common.netty.channel.socket.nio.AbstractNioSelector.run(AbstractNioSelector.java:337)
	at org.elasticsearch.common.netty.channel.socket.nio.AbstractNioWorker.run(AbstractNioWorker.java:89)
	at org.elasticsearch.common.netty.channel.socket.nio.NioWorker.run(NioWorker.java:178)
	at org.elasticsearch.common.netty.util.ThreadRenamingRunnable.run(ThreadRenamingRunnable.java:108)
	at org.elasticsearch.common.netty.util.internal.DeadLockProofWorker$1.run(DeadLockProofWorker.java:42)
	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
	at java.lang.Thread.run(Thread.java:748)
[2019-06-06 14:48:26,755][DEBUG][action.search.type       ] [745e0cf8-855b-48c9-91c0-3973b12ae3bf] All shards failed for phase: [query_fetch]
org.elasticsearch.action.NoShardAvailableActionException: [nagioslogserver][0] null
	at org.elasticsearch.action.search.type.TransportSearchTypeAction$BaseAsyncAction.start(TransportSearchTypeAction.java:160)
	at org.elasticsearch.action.search.type.TransportSearchQueryAndFetchAction.doExecute(TransportSearchQueryAndFetchAction.java:57)
	at org.elasticsearch.action.search.type.TransportSearchQueryAndFetchAction.doExecute(TransportSearchQueryAndFetchAction.java:47)
	at org.elasticsearch.action.support.TransportAction.execute(TransportAction.java:75)
	at org.elasticsearch.action.search.TransportSearchAction.doExecute(TransportSearchAction.java:104)
	at org.elasticsearch.action.search.TransportSearchAction.doExecute(TransportSearchAction.java:43)
	at org.elasticsearch.client.node.NodeClient.execute(NodeClient.java:98)
	at org.elasticsearch.client.FilterClient.execute(FilterClient.java:66)
	at org.elasticsearch.rest.BaseRestHandler$HeadersAndContextCopyClient.execute(BaseRestHandler.java:92)
	at org.elasticsearch.client.support.AbstractClient.search(AbstractClient.java:338)
	at org.elasticsearch.rest.action.search.RestSearchAction.handleRequest(RestSearchAction.java:84)
	at org.elasticsearch.rest.BaseRestHandler.handleRequest(BaseRestHandler.java:53)
	at org.elasticsearch.rest.RestController.executeHandler(RestController.java:225)
	at org.elasticsearch.rest.RestController.dispatchRequest(RestController.java:170)
	at org.elasticsearch.http.HttpServer.internalDispatchRequest(HttpServer.java:121)
	at org.elasticsearch.http.HttpServer$Dispatcher.dispatchRequest(HttpServer.java:83)
	at org.elasticsearch.http.netty.NettyHttpServerTransport.dispatchRequest(NettyHttpServerTransport.java:327)
	at org.elasticsearch.http.netty.HttpRequestHandler.messageReceived(HttpRequestHandler.java:63)
	at org.elasticsearch.http.netty.pipelining.HttpPipeliningHandler.messageReceived(HttpPipeliningHandler.java:60)
	at org.elasticsearch.common.netty.channel.SimpleChannelHandler.handleUpstream(SimpleChannelHandler.java:88)
	at org.elasticsearch.common.netty.handler.codec.http.HttpChunkAggregator.messageReceived(HttpChunkAggregator.java:145)
[2019-06-06 14:48:31,763][DEBUG][action.search.type       ] [745e0cf8-855b-48c9-91c0-3973b12ae3bf] All shards failed for phase: [query_fetch]
[2019-06-06 14:48:31,771][DEBUG][action.search.type       ] [745e0cf8-855b-48c9-91c0-3973b12ae3bf] All shards failed for phase: [query_fetch]
[root@nagiosls1 ~]#
How many node cluster is this?
How much free disk space is on each of the instances?
df -h
Sampath.Basireddy
Apologies fo the late response.
It is just 1 node cluster.
[root@nagiosls1 ~]# df -h
Filesystem                 Size  Used Avail Use% Mounted on
/dev/mapper/vg00-lv_root   2.9G  1.6G  1.1G  60% /
devtmpfs                    24G     0   24G   0% /dev
tmpfs                       24G   24K   24G   1% /dev/shm
tmpfs                       24G  330M   24G   2% /run
tmpfs                       24G     0   24G   0% /sys/fs/cgroup
/dev/mapper/vg00-lv_usr    6.7G  2.4G  3.9G  38% /usr
/dev/sda1                  477M  117M  336M  26% /boot
/dev/mapper/vg00-lv_tmp    4.7G   21M  4.5G   1% /tmp
/dev/mapper/vg00-lv_var     29G  3.6G   24G  14% /var
/dev/mapper/vg_apps-lvol0  739G  273G  436G  39% /usr/local/nagioslogserver
tmpfs                      4.8G     0  4.8G   0% /run/user/1384400234
tmpfs                      4.8G     0  4.8G   0% /run/user/13802
[root@nagiosls1 ~]#
An FYI, since the error earlier was mainly talking about "There is insufficient memory for the Java Runtime Environment to continue", I went ahead and increased the memory from 32 to 48gigs and elasticsearch kind of stopped stopping as frequently as it used to happen. But it still continue to go into exit state like once or twice a week.
Sampath.Basireddy wrote:It is just 1 cluster.
    [root@nagiosls1 ~]#
Because you have so many GB allocated to tmpfs which can consume all the memory on the server I'm going to make a suggestion based on what you described that may additionally help
Edit /etc/sysconfig/elasticsearch on about the 5th line comment this out
change this
ES_HEAP_SIZE=$(expr $(free -m|awk '/^Mem:/{print $2}') / 2 )m
to this
#ES_HEAP_SIZE=$(expr $(free -m|awk '/^Mem:/{print $2}') / 2 )m
then below that add this line
ES_HEAP_SIZE=16g
This will give a fixed size requirement of 16g instead of being fluid based on total server memory.
This setting will take effect the next time elasticsearch is updated.
Sampath.Basireddy
Sure, I can do that.
Don't know what happened, today elasticsearch exited like 4 times so far. I don't really see any issue with memory usage though. Any other logs we can look at to identify what is causing the service to exit?
Sampath.Basireddy
I see the ES_HEAP_SIZE is set to 20480m
# Directory where the Elasticsearch binary distribution resides
APP_DIR="/usr/local/nagioslogserver"
ES_HOME="$APP_DIR/elasticsearch"
# Heap Size (defaults to 256m min, 1g max)
# Nagios Log Server Default to 0.5 physical Memory
ES_HEAP_SIZE=20480m
# Heap new generation
#ES_HEAP_NEWSIZE=
# max direct memory
#ES_DIRECT_SIZE=
# Additional Java OPTS
#ES_JAVA_OPTS=
# Maximum number of open files
MAX_OPEN_FILES=65535
# Maximum amount of locked memory
MAX_LOCKED_MEMORY=unlimited
# Maximum number of VMA (Virtual Memory Areas) a process can own
MAX_MAP_COUNT=262144
# Elasticsearch log directory
LOG_DIR=/var/log/elasticsearch
# Elasticsearch data directory
DATA_DIR="$ES_HOME/data"
