Error when using check_docker.py
dclsystems
I am getting error while using https://nagiosxi.distributel.net/nagios ... _docker.py file:
root@docker:/usr/local/ncpa/plugins# python /usr/local/ncpa/plugins/check_docker.py -H http://127.0.0.1:2375 -s /var/run/docker.sock --check-type 'containers_healthy' --all -t 0 --ignore-no-healthcheck -l -w '50:' -c '30:'
Traceback (most recent call last):
File "/usr/local/ncpa/plugins/check_docker.py", line 988, in <module>
_ = main()
File "/usr/local/ncpa/plugins/check_docker.py", line 959, in main
checks = choose_checks(options)
File "/usr/local/ncpa/plugins/check_docker.py", line 226, in choose_checks
check_data = get_threshold_maps(options.warning, options.critical, selection)
File "/usr/local/ncpa/plugins/check_docker.py", line 329, in get_threshold_maps
for triplet in zip(attrs.keys(), warning_list, critical_list):
AttributeError: 'list' object has no attribute 'keys'
RD
_ = main()
RD
npolovenko
- Support Tech
Re: Error when using check_docker.py
Hello, @dclsystems. First, let's make sure that you have installed all the required python modules. Please run the following commands in order, from the command line and let me know if at least one of them errors out.
su nagios -c 'python -c "import sys"'
su nagios -c 'python -c "import optparse"'
su nagios -c 'python -c "from os.path import expanduser"'
su nagios -c 'python -c "import subprocess"'
su nagios -c 'python -c "import urllib"'
su nagios -c 'python -c "import json"'
su nagios -c 'python -c "import shlex"'
su nagios -c 'python -c "import signal"'
su nagios -c 'from copy import copy"'As of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new Privacy Policy.
I am receiving the same error. I ran the commands you suggested. They error out with:
I'm not sure exactly what this command is supposed to do, but the " is throwing it off, and also there is no "from" command installed so I'm thinking maybe that is supposed to be something completely different and you just had a typo or two?
I still receive this error:
This is after following instructions at https://assets.nagios.com/downloads/nag ... ios-XI.pdf and successfully going through the wizard to modify a docker host (via ncpa).
[root@ma1p-nagiosxi ~]# su nagios -c 'from copy import copy"'
bash: -c: line 0: unexpected EOF while looking for matching `"'
bash: -c: line 1: syntax error: unexpected end of file
_ = main()
npolovenko wrote:Hello, @dclsystems. First, let's make sure that you have installed all the required python modules. Please run the following commands in order, from the command line and let me know if at least one of them errors out.Code: Select all
su nagios -c 'python -c "import sys"' su nagios -c 'python -c "import optparse"' su nagios -c 'python -c "from os.path import expanduser"' su nagios -c 'python -c "import subprocess"' su nagios -c 'python -c "import urllib"' su nagios -c 'python -c "import json"' su nagios -c 'python -c "import shlex"' su nagios -c 'python -c "import signal"' su nagios -c 'from copy import copy"'
npolovenko
- Support Tech
@emarmonti, Sorry, I didn't spell the last command right. Please try:
su nagios -c 'python -c "from copy import copy"'As of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new Privacy Policy.
Unfortunately running that command manually and then forcing a check on my "Docker - Container *" checks yields the same error. I can see that check_docker.py already is importing all of these modules.
Here is the error:
Here is the error:
_ = main()
AttributeError: 'list' object has no attribute 'keys'Re: Error when using check_docker.py
Can you share the output of:
I can't actually get this plugin to work against:
Despite the socket responding to cURL:
sudo docker version
python --version
Server: Docker Engine - Community
Engine:
Version: 18.09.2
API version: 1.39 (minimum version 1.12)
Go version: go1.10.6
Git commit: 6247962
Built: Sun Feb 10 03:47:25 2019
OS/Arch: linux/amd64
Experimental: false
# python check_docker.py -H http:/v1.39/ -s /var/run/docker.sock --check-type 'containers_cpu'
File "check_docker.py", line 988, in <module>
_ = main()
File "check_docker.py", line 959, in main
File "check_docker.py", line 226, in choose_checks
File "check_docker.py", line 329, in get_threshold_maps
# curl --unix-socket /var/run/docker.sock http:/v1.39/containers/json
## Valid JSON shows up
npolovenko
- Support Tech
Hello!
Docker wasn't actually installed on the Nagios XI Server. Given the fact that the Docker wizard was already installed, I kind of assumed all dependencies would exist to use it.
I went ahead and installed docker-ce. The check is still failing. Here are the version numbers you were asking for.
[emarmonti@ma1p-nagiosxi ~]$ docker --version
Docker version 18.09.6, build 481bc77156
[emarmonti@ma1p-nagiosxi ~]$ python --version
Python 2.7.5
[emarmonti@ma1p-nagiosxi ~]$-
npolovenko
- Support Tech
@emarmonti, We found a bug in the plugin and submitted a task for the dev team. Please check back in this thread some time next week for an update. Once the bug fix has been released, we'll provide you with the new version.
npolovenko
- Support Tech
@emarmonti, UPDATE: Please move the existing check_docker plugin to a backup directory and use the modified plugin I attached to this message:
Don't forget to give permissions to the new plugin before executing it:
mv /usr/local/nagios/libexec/check_docker.py /tmp/Code: Select all
chmod 777 /usr/local/nagios/libexec/check_docker.pyYou do not have the required permissions to view the files attached to this post.
