Defintions of plugin commands not defined in nrpe.cfg?
riahc3
Post by riahc3 »
Hello
I was going to use check_uptime but I see it isnt defined in nrpe.cfg First, question: Why?
Second, what is the best or standard way to define all the commands?
npolovenko
Re: Defintions of plugin commands not defined in nrpe.cfg?
Post by npolovenko »
Hello, @riahc3. Depending on the NRPE build, only some or no services will be defined by default. Here is the definition that you can paste into the nrpe.cfg file:
command[check_uptime]=/usr/local/nagios/libexec/check_uptime $ARG1$
You can define all other commands in a similar way:
command[command_name_here]=path/to/the/plugin/ $ARG1$
Then restart the nrpe to apply changes and run this command to test out the command:
/usr/local/nagios/libexec/check_nrpe -H 127.0.0.1 -c check_uptime
