I'm running Nagios XI on an offline Centos 7.6 server
I tried upgrading from 5.5.11 to 5.6.2 by downloading the latest RPM from https://repo.nagios.com/?repo=offline
I run the upgrade script which completes successfully and when I do:
rpm -qa | grep Nagios
All the Nagios RPM's are on version 5.6.2
However, when I log into Nagios XI web interface, it still displays "Nagios XI 5.5.11" in the bottom left of the browser.
I've tried rebooting the server, but get the same result.
Nagios XI RPM upgrade to 5.6.2 still showing old version
psundstrom
psundstrom
Re: Nagios XI RPM upgrade to 5.6.2 still showing old version
I found the problem.
Turns out our Centos security profile has noexec set on /tmp, which prevents the rest of the upgrade to complete.
As I'd rebooted the server, the original nagiosxi RPM no longer existed in /tmp.
To get around this, I had to complete the install with:
rpm2cpio nagiosxi-5.6.2=2.el7.x86_64.rpm |cpio -icvdum
tmp/nagiosxi/rpmupgrade-
benjaminsmith
Hi @psundstrom,
Thanks for the update and glad to hear it's been resolved. Did you have any other questions or may we close this one out?
