Installing Nagios XI error
idiot90907
Post by idiot90907 »
see the atttachent!
idiot90907
ERROR: Failed to update automysqlbackup with MySQL password
What version of Nagios XI are you using? latest
Linux Distribution and version? CentOS7
32 or 64bit? 64bit
VMware Image or Manual Install of XI? VMware
Are there special configurations on your system, ie; is Gnome installed? Are you using a proxy? Are you using SSL? no
benjaminsmith
Re: Installing Nagios XI error
Post by benjaminsmith »
Hi @idiot90907,
It looks like you changed the default passwords for MySQl. Did you follow our guide to changing the MySQL account passwords as you'll need to change the settings in a few places (e.g. /root/scripts/automysqlbackup) ?
How to Change Default Passwords
Please verify those settings and then try to re-install. Please post the install log again if it fails.
