Inbound email processing error
gwakem
Post by gwakem »
XI 5.6.2 on RHEL 7.5
I have enabled inbound mail settings, tested successfully, and verified xi is removing emails after reading them.
However, I only get a reply email stating "Could not submit command due to missing hash data. Did you reply with the full email?"
Here is a sample of the reply I sent:
ack
Testing ack by email
On Thu, 2019-06-06 at 13:59 -0400, Nagios XI wrote:
---- Respond above this line ----
Date/Time: 06/06/2019 13:59:58
Notification Type: PROBLEM
Service: Service status for: firewalld
Host: xxxx
Address: x.x.x.x
Additional Info: CRITICAL: firewalld is stopped (should be running)
Notification Author:
Notification Comment:
Respond: https://xxxxxxxxxxxx/nagiosxi/rr.php?oi ... 5e8c49793d
Nagios URL: https://xxxxxxxxxxxxx/nagiosxi/
To reply, keep the following data in your response email.
##YWRiMmRkNjJmZTY4NTcyMVN2aUtXaUtkRVV5cVN2ajl0dVhTUzIxU05NL29EQjFhMURRMlRKT3ltU2pVcVZWVDBXSGErdVhCT29LK3FabThhVTZDckVGMGRHVGoyd2NTZG4yWXJRPT0=##
Is there a way to further debug what is going wrong? For clarity, I also tried with the hash directly below the ack and comment, but no luck their either.
Griffin Wakem
npolovenko
Re: Inbound email processing error
Post by npolovenko »
Hello, @gwakem. What email client are you using to acknowledge notification emails? On the nagios server please tail the cleaner log:
tail -f /usr/local/nagiosxi/var/cleaner.log
And while this command is running, respond to a notification email with:
ack
And see what kind of errors the command will show.
gwakem
Post by gwakem »
I am using Evolution on a Fedora 29 system. I will try via webmail and exchange on a windows 10 system also.
I will do additional testing with the other email clients and OS's later today/early next week and report back.
The error that I found in the logs stated this for Evolution.
Error - Could not find a valid hash in the email sent
PHP Catchable fatal error: Object of class stdClass could not be converted to string in /usr/local/nagiosxi/html/includes/components/xicore/xicore.inc.php on line 550
Griffin Wakem
npolovenko
@gwakem, Sounds good. Please try a different mail client and let us know.
