I need to monitor some Windows hosts (Windows Server 2003, 2012, 2016 and Windows XP, 7, 10).
But I'm not sur what agent should I use.
I've read this :
https://assets.nagios.com/downloads/ncp ... arison.pdf
https://support.nagios.com/forum/viewto ... =7&t=48325
So, NCPA is the official Nagios agent. But then why does Nagios XI propose in its wizard to install NSCP instead of NCPA?
I only need Active checks.
I don't think I need the GUI: the Nagios XI assistant should be sufficient? In which case can the NCPA GUI be useful, especially when you have hundreds of hosts to monitor?
On the 2nd link, it is said that NCPA is in active development. This post is a year old, how did it evolve?
Does one perform better than the other?
I use NRPE for monitoring Linux, which one is closer to NRPE ? Or maybe I should use NCPA instead of NRPE for Linux?
I need to monitor basics system information (ping, CPU load, RAM usage, disks usage...), some services and maybe some processes.
In the end, which one would you recommend?
Other question,
I'll need to deploy agents on about 100 Windows hosts. I'm thinking of using Ansible for that.
Do you have an Ansible playbook to share?
Can I use it for NCPA and NSCP? Maybe it's easier with one of them?
Thank you!
NSCP vs NCPA ?
Re: NSCP vs NCPA ?
Good questionSo, NCPA is the official Nagios agent. But then why does Nagios XI propose in its wizard to install NSCP instead of NCPA?
Probably not great for monitoring hundreds of hosts given that the NCPA GUI only displays local system information. XI would be used to monitor the hundreds of hosts.I don't think I need the GUI: the Nagios XI assistant should be sufficient? In which case can the NCPA GUI be useful, especially when you have hundreds of hosts to monitor?
Changle log: https://github.com/NagiosEnterprises/nc ... HANGES.rstOn the 2nd link, it is said that NCPA is in active development. This post is a year old, how did it evolve?
I'm not aware of any performance differences between the two.Does one perform better than the other?
The Linux NRPE agent is another of our agents. I don't think I would have any reason to use one over the other, other than it may be preferable/easier to administer an environement if all the machines used a single client like NCPA.I use NRPE for monitoring Linux, which one is closer to NRPE ? Or maybe I should use NCPA instead of NRPE for Linux?
It's mostly a personal preference, but I like NCPA given that it is our agent and it can be used across multiple platforms.I need to monitor basics system information (ping, CPU load, RAM usage, disks usage...), some services and maybe some processes.
We have a tutorial here:Do you have an Ansible playbook to share?
https://support.nagios.com/kb/article/n ... l-819.html
