my script not run through nrpe but can run it without nrpe
baber
Post by baber »
Dear friend
Hi
i have write script but when i run it in my os the out put is ok but while run that through nrpe it cannot show correct output
i have attache the script
this is my output
[root@rac1 tmp]# ./check_my_hwclock.sh
Hardware clock is OK
[root@rac1 tmp]# /usr/local/nagios/libexec/check_nrpe -H localhost -c check_my_hwclock
Hardware clock has Problem
[root@rac1 tmp]#
check_my_hwclock.sh
(464 Bytes) Downloaded 248 times
Re: my script not run through nrpe but can run it without nr
Can this be run by your NRPE user (nagios or nrpe)? Does it need elevated permissions?
su nagios
baber
Post by baber »
Dear friend
nagios user is nologin
[root@rac1 ~]# cat /etc/passwd | grep nagios
nagios:x:1000:1000::/home/nagios:/sbin/nologin
actually while use su nagios will be show
[root@rac1 ~]# su nagios
This account is currently not available.
Can you temp change it to /bin/bash so you can see the results of running this as the user that will actually be executing the checks?
