Dashboard Creation Doc
SteveBeauchemin
Post by SteveBeauchemin »
Is there an actual document that shows how to make dashboards, add items to it, resize them, tie them to data sources? The Admin document is very good. Getting data into the tool is good. But once the data is there you need to see it. Help me see it please.
I am trying to migrate from ELK to NLS and would like to read a document on making visualizations. I'm not looking to watch a video. Seen enough videos. I like to read.
Steve B
XI 5.7.3 / Core 4.4.6 / NagVis 1.9.8 / LiveStatus 1.5.0p11 / RRDCached 1.7.0 / Redis 3.2.8 /
SNMPTT / Gearman 0.33-7 / Mod_Gearman 3.0.7 / NLS 2.0.8 / NNA 2.3.1 /
NSClient 0.5.0 / NRPE Solaris 3.2.1 Linux 3.2.1 HPUX 3.2.1
Re: Dashboard Creation Doc
This is probably the closest we have to what you are looking for
https://assets.nagios.com/downloads/nag ... Server.pdf
SteveBeauchemin
Thanks Scott, that'll work. Understanding what to click to add items and make a dashboard was the basic thing I was asking for.
Is it possible to add other visualizations? Or modify existing visualizations to improve the look and feel?
For example, if I just want a 'totals' number displayed, what I get is left/top justified. I would like it to be center/center justified in the frame. Some simple refinements like that would be nice. Is that possible? I have not looked under the covers for that.
Steve B
As of now unfortunately we do not have any method to create customization for the panels.
I will note the panels are stored in /var/www/html/nagioslogserver/www/app/panels/ but at present these will be over-written on upgrade.
SteveBeauchemin
Thanks for the info. I have just now started on the learning path for NLS. Should be fun.
You can close this if you like.
Steve B
SteveBeauchemin wrote:Thanks for the info. I have just now started on the learning path for NLS. Should be fun.
Steve B
Great!
Locking
