Performance parameters for f5/firewall/load balancers
sajid4u2c
Post by sajid4u2c »
Hi All,
Could you please suggest a SNMP based NagiosXI plugin for monitoring the security devices f5/firewall/load balancers .
I have the below details of the SNMP .
SNMP v3 Username
Authentication Password
Privileged Password
Authentication Protocol
Privileged Protocol
Parmaters to be monitored : Memory, cpu, disk etc
Nagios monitor: 5.5.2
Thanks.
cdienger
Re: Performance parameters for f5/firewall/load balancers
Post by cdienger »
sajid4u2c
Post by sajid4u2c »
Thanks for the link.
Have followed the instructions and installed the plugin.
However, when i run it , I am getting the below PERL module error.
 ./check_nwc_health --help
Can't locate Module/Load.pm in @INC (@INC contains: /usr/local/lib64/perl5 /usr/local/share/perl5 /usr/lib64/perl5/vendor_perl /usr/share/perl5/vendor_perl /usr/lib64/perl5 /usr/share/perl5 .) at ./check_nwc_health line 2747.
I think some dependency package of perl is required. Can I go ahead and install (how?) ? Will that hamper the existing Nagios monitoring?
I am worried as I have no test lab and trying out this in PROD nagios server.
Regards.
Try installing the missing perl module by running:
yum install perl-Module-Load
Let us know if this helped.
sajid4u2c
Post by sajid4u2c »
Yum in not configured in the nagios server.
Can I please get the link to the RPM please.
Regards,
What operating system and version are you running?
Or you could compile it from here
https://metacpan.org/pod/Module::Load
sajid4u2c
Post by sajid4u2c »
we are using : CentOS Linux release 7.5.1804 (Core)
We need to write script for compiling this load.pm ? or just need copy the files. Please suggest.
Yo would need to download the tarball then run
   tar xzf Module-Load-0.34.tar.gz
   cd Module-Load-0.34
   perl Makefile.PL
   make
   make test
   make install
sajid4u2c
Post by sajid4u2c »
Installation done.
I have tested the below command from nagios terminal for checking the load and getting the error as stated below.
Could you please let me know, if I am missing anything in the arguments.
/usr/local/nagios/libexec/check_nwc_health -v --mode cpu-load --domain tcp --hostname host  --port 161  --username user --authpassword authpswd --authprotocol sha --privpassword authpswd  --privprotocol aes
CRITICAL - cannot create session object: Unable to resolve the TCP/IPv4 address "AUM1FWL-PRI001"
Regards,
sajid4u2c
Post by sajid4u2c »
Sorry for the above post. I have replaced the hostname with IP address and its working now
Thanks for the help and support.
sample output:
OK - memory 20 (Slot-0 Management Memory) usage is 68.61%
checking storagesram
memory 20 (Slot-0 Management Memory) usage is 68.61% | 'memory_Slot-0 Management Memory_usage'=68.61%;90;95;0;100
