Is there an updated check_docker.py script?
upon running the check_docker wizard we're getting:
Maxwell Ramirez
check_docker
Maxwellb99
check_docker
npolovenko
- Support Tech
Re: check_docker
Hello, @Maxwellb99. I'm attaching the most recent version to this message.
Replace the existing plugin located in/usr/local/nagios/libexec/check_docker.py
Give it the permissions:
If the error persists, please share the command definition.
chmod 777 /usr/local/nagios/libexec/check_docker.py You do not have the required permissions to view the files attached to this post.
