Nagios core Running / Not Runnig
rafaellouroreis
Post by rafaellouroreis »
Hello guys,
Since 2 weeks, without any change, my nagios is not working 100 % at all.
He start so show "No Matching Services" for some hosts, and after a while is again ok.
Than dont show nothinhg at all, and again, after a while, 100% ok.
i see that nagios core change alone between Running and Not running in seconds..
What can this be ?
Im using Nagios 4.2.2 core at a Ubuntu linux
rafaellouroreis
Re: Nagios core Running / Not Runnig
I just foud this:
/dev/mapper/nagios--vg-root is full. i think this can be my problem ?? !
i give already more 10 GB at vCenter ( im using vmeare ) for the disk of this VM, but i dont know how to make tihis partition bigger at linux.
i´m using Ubuntu Core.
rafaellouroreis
That was nothing the Problem !!!! after more space, still the same problem ...
rafaellouroreis wrote:That was nothing the Problem !!!! after more space, still the same problem ...
Did you verify the current nagios config?
bin/nagios -v etc/nagios.cfg
then restart nagios?
rafaellouroreis
Configuratios is ok, no errors.
As i wrote, no changes was made at all. After a Reboot from linux, it works again for a while and the problem is comming again.
I dont know what can cause this bahavior, nacios core work stop to work alone, than work again...
rafaellouroreis
I still have problem with space!!! :(
i dont understand: See /DEV/mapper/Nagios--vg-root ( 100% full ) how i can make this bigger????
First make sure you have a backup of your system, then you would run something like the following
pvresize /dev/sda5
lvresize /dev/mapper/Nagios--vg-root /dev/sda5
resize2fs /dev/mapper/Nagios--vg-root
Finally, once these are done verify it has increased
df -h
(Adapted from our Resizing The Virtual Machine Disk Size doc with different volume labels)
rafaellouroreis
Thanks!!!! a zilion times thanks!!!!!!!!!!!!!!!!
Nagios have enough space now, hope this fix the problem!!! you save my day!!! :D
rafaellouroreis wrote:Thanks!!!! a zilion times thanks!!!!!!!!!!!!!!!!
Great!
Locking
