Hi there,
Urgent help needed.
I am trying to monitor Jenkins jobs which are triggered periodically using NagiosXI trial version.
My configuration is as follows:
check_jenkins_cron.pl -j jenkinsjobname -l jenkinsurl -w 60 -c 120
And I have set jenkins job to trigger every minute for testing purpose and its successful.
Still the plugin outputs as below:
CRITICAL - 'jenkinsjobname' has not run successfully for 15h 56m 31s. No runs since. http://jenkins:8080/job/jobname/59/
Anyone knows whats wrong with it?
Thanks in Advance,
Poonam Davari
check_jenkins_cron.pl is not detecting succesful builds
puni21davari
Re: check_jenkins_cron.pl is not detecting succesful builds
Are the times synced on the XI server and the Jenkins server?
run the following on each from the CLI
do they match including timezone?
date-
puni21davari
Now it seems working fine.
I haven't changed anything in setup and as I checked both servers time is in sync.
Yesterday I did not check that, so not sure what was the issue before.
That's odd but glad it's working.puni21davari wrote:Now it seems working fine.
Locking thread
