All Switch Wizard added devices reporting 0 after Midnight
jeevans
Post by jeevans »
Nagios XI 5.6.1 install that's been working great for years. However, beginning last night any device I used the "Network Switch / Router" wizard to monitor started showing 0 up/down starting around Midnight last night. An SNMP walk of the devices show proper bandwidth at the appropriate SNMP OID.
I've rebooted the server, shut down and added processors (it was running around 68% previously), and ran a database repair.
Last edited by benjaminsmith on Thu Jun 13, 2019 10:16 am, edited 1 time in total.
Reason: saved profile
jeevans
Re: All Switch Wizard added devices reporting 0 after Midnig
Post by jeevans »
Solution
I ran "LANG=C LC_ALL=C /usr/bin/mrtg /etc/mrtg/mrtg.cfg --lock-file /var/lock/mrtg/mrtg_l --confcache-file /var/lib/mrtg/mrtg.ok"
This found duplicate entries in /etc/mrtg/conf.d/ I removed the duplicate entries and everything is working as designed.
benjaminsmith
Post by benjaminsmith »
Hi @jeevans,
Thanks for posting the solution. Glad you got it solved.
We'll close this thread. However, if you have any new questions, please feel free to open another.
