We need integrated nagios core authentication with SAML ( to use in Multi-Factor Authentication) , for this we think that we could use mod_auth_mellon (https://github.com/Uninett/mod_auth_mellon)
Would authentication be possible using the indicated Apache mod?
if yes, how? We don't know how perform the configuration for use this Apache mod.
Thanks.
SAML authentication (mod_auth_mellon)
pepe_carlos
Re: SAML authentication (mod_auth_mellon)
Maybe? I don't know your SAML providerpepe_carlos wrote:Would authentication be possible using the indicated Apache mod?
Likely by marrying-up the GitHub instructions for configuration to the Apache configs generated for Nagios Core. Instead of using basic auth with an htpasswd file, you could probably drop the relevant mod_auth_mellon configs in-place.pepe_carlos wrote:if yes, how? We don't know how perform the configuration for use this Apache mod.
It's an Apache question more than it is a Nagios Core question, though. Nagios Core doesn't have "authentication" -- it delegates those duties to the app server (Apache by default, nginx, lighttpd, whatever you wanna use).
pepe_carlos
the provider is Azure AD.Maybe? I don't know your SAML provider
The problem is that we don't know how we can configure it for us is something new and does not have any idea that how we can do it.
I don't know if we are going to be much help creating the apache config for your SAML provider, but mcapra is right, if you geta configuration that works on a basic apache page/site, you could likely somehow marry up that configuration with your nagios apache configuration and use that instead of basic auth.
pepe_carlos
OK, I try to get help in Apache forum.
Thanks.
Thanks.
no problempepe_carlos wrote:OK, I try to get help in Apache forum.
Thanks.
