Can't run manual backup after updating to 5.6.3
rferebee
Post by rferebee »
I'm attempting run a manual backup from the command line after updating to version 5.6.3 and for some reason it keeps failing at the same spot. It's referencing a password in the script that I cannot find.
The last backup that completed successfully was on 6/11/2019.
I haven't changed any passwords, so I'm not sure what is causing it to fail. Even if I try to run the backup from the GUI nothing happens.
I'm using this document for reference: https://assets.nagios.com/downloads/nag ... ios-XI.pdf
Thank you.
Re: Can't run manual backup after updating to 5.6.3
You have a crashed table in your Database that needs to be repaired before the backup can run, follow this document
https://assets.nagios.com/downloads/nag ... tabase.pdf
rferebee
Post by rferebee »
Yes, that resolved the issue. Thank you very much, you can mark this resolved.
rferebee wrote:Yes, that resolved the issue. Thank you very much, you can mark this resolved.
Great!
Locking
