nagiosxi graphs problems
maxamed
Post by maxamed »
hi everyone
it is first time i post here and hope to get usefull post.
i have installed nagiosxi and it works fine but there is no graphs. i have a message that says (Return code of 126 is out of bounds - plugin may not be executable)
thanks all
Re: nagiosxi graphs problems
If you are getting plugin is not executable it is possible you have a permissions problem with the plugin you are trying to use.
What plugin are you using?
