User Notification Time Periods
davide.bonicelli
Post by davide.bonicelli »
Hi, i've got a nagios with different user with differents time notification with differents service escalation..a complicated case!
I would have found the solution for all, if i could set different time notification for users..
The problem is, for example, that i can only set one time for a day..like sunday from 05.00 to 17.00
But i need to set the time notification from sunday at 17.00 to monday at 05.00
and then from monday 17.00 at tuesday at 05.00 and so on..
i think there is no solution for this..what do you think?
npolovenko
Re: User Notification Time Periods
Post by npolovenko »
Hello, @davide.bonicelli. You can't define multiple time periods for a single day, but have you considered using custom notification periods for contacts instead?
You should be able to define multiple time periods for each day, like this:
There should be a contact that corresponds to each user in XI.
davide.bonicelli
Hey, i think it could works!
Thanks!!
benjaminsmith
Post by benjaminsmith »
Hi Davide,
Thanks!!
Just let us know if you have any other questions.
