Respond URL broken
arnab.roy
Respond URL broken
Post by arnab.roy »
Hi Guys,
I think this is broken as the url sent out by %respondurl variable is https://xiserver/rr.php?uid=72-1625-b8a ... 4713ab0076 instead of https://xiserver/nagiosxi/rr.php?uid=72-1625-b8a5d9f4434c768c103e164713ab0076.
Can one of you guys look at this.
Cheers
Arnab
Re: Respond URL broken
Arnab,
What version of XI are you running?
Do you have the full path set at
Admin -> Manage System Config -> Program URL: ?
arnab.roy
Post by arnab.roy »
Yes, I do have the correct path set. I am running r2.2 . This is only happening to the respond url within notifications. All other links seem to be fine.
Strange, this is the value the script pulls...
Can you run the following from the command line to see if it has your full path to nagiosxi
echo "select value from xi_options where name='url';" | psql nagiosxi nagiosxi
arnab.roy
Post by arnab.roy »
Hi Scott,
Thanks for pointing towards that I found the path was set to https://server.khipu-networks.com under system config I have changed this to https://server/nagiosxi
Cheers
Arnab
