Hello there,
I was trying to see if i can send the notifications using AWS SNS instead of postfix or mailx.
I have a topic and keys ready but not quite sure what to do after that.
Could someone explain me this?
Send Nagios notifications using AWS SNS instead of postfix.
karthikv248
Re: Send Nagios notifications using AWS SNS instead of postf
You should be able to, as long as you can send the messages from the CLI of the Nagios Core system you should be able to set it up as a command to be used by your contact as the host/service notification handler.
I did find this:
https://brooksgarrett.com/blog/nagios-s ... mazon-sns/
I did find this:
